CVF Alternator Brackt
Old May 13, 2015 | 10:26 AM
70cutty's Avatar
Beer Connoisseur
After reading about constant complaints about parts that don't work I thought I post a positive review for parts that work.
I bought a alternator bracket from CVF Racing.
The bracket came well packaged with clear instructions that included pictures, which made installation really simple. It lined up the alternator pulley perfect with the rest of the pulleys. It's a great looking piece for those that are looking to spruce up their engine bay and get rid of the overkill stock brackets and not break bank. I am also using their pulleys.
American made product, great quality, great fitment and awesome customer service.
Just thought I give some credit where the credit is due and share this with you guys.
Here are some pictures of the bracket
Installed
Old May 13, 2015 | 12:01 PM
RandyS's Avatar
Looks like it is in good company!!!!!!
Old May 13, 2015 | 02:11 PM
Rallye469's Avatar
Could you please take a closer picture of that bracket installed?
please, please, please!?!?!?!?
I've NEVER seen this bracket.
-pete
I've had trouble snapping off bolts on my BOP piece.
(lotsa time digging out steel bolts out of aluminum heads with ez-outs and dremmels lately)
Old May 13, 2015 | 02:43 PM
70cutty's Avatar
Beer Connoisseur
No problem, I'll take a picture when I get home. I never seen it before either, ran into their pulleys on Ebay, decided to check out the store and seen the bracket. Looks a lot better than BOP and much sturdier.
Old May 13, 2015 | 02:53 PM
Rallye469's Avatar
Thank you SO much!
I look forward to seeing this option.
2 weekends ago I was on my way to the track, looked down and saw my volt gauge at 12 and not the usual 13.5+...
popped the hood and found the alternator DANGLING by a bolt. Limped home on battery.
This has happened twice before. The BOP unit worked well for a time...but has turned to junk in the last year.
-pete
Old May 13, 2015 | 04:25 PM
70cutty's Avatar
Beer Connoisseur
Here it is, I hope this helps.
[/url]
[/url]
[/url]
Old May 13, 2015 | 04:36 PM
70cutty's Avatar
Beer Connoisseur
Thanks Randy.
Old May 13, 2015 | 09:23 PM
Mr Nick's Avatar
Nice charge cable. I'm wrapping up a full electrical accessory upgrade using products from http://www.ceautoelectricsupply.com/index.html
Old May 14, 2015 | 08:00 AM
Rallye469's Avatar
This looks awesome!
Really stout with plenty of cross bracing.
Thanks for the extra picts!
-Does it use the top bolt hole in your heads or the bottom?
(of the two furthest left in the head)
-Are there alternate configurations to hang the alternator high or low?
Nice looking mill but the way!
-pete
Old May 14, 2015 | 08:06 AM
olds3442's Avatar
also looking for a low mount, sounds like I don't want bop, but It will be on a race application only
Old May 14, 2015 | 09:48 AM
Rallye469's Avatar
OLDS3442, If I was running steel heads, it might not be the same issue.
AND, my BOP unit held up for awhile...but ultimately, it's kinda flimsy.
This unit looks a LOT stronger.
-peter
Old May 14, 2015 | 11:49 AM
70cutty's Avatar
Beer Connoisseur
This looks awesome!
-pete
Thanks Pete, I believe it's the top bolt that it mounts to.
Unfortunately I don't think it can be mounted low but it's nice enough so it doesn't bother me.
Old May 14, 2015 | 07:15 PM
scott442's Avatar
Off topic but what brand upper control arms are those 70cutty?
Old May 15, 2015 | 08:26 AM
70cutty's Avatar
Beer Connoisseur
They are chinesium Heavy Duty control arms. I used them and abused them on my Chevelle for last 4 years. Did few autocross events and plenty of wild cruises and trips to the track. When I was doing the engine swap I decided to put them on the Cutlass.
When compared to UMI on my buddies El Camino, these just seem better quality.The welds look great, reinforced in critical areas, seem like heavier gauge metal than UMI too.
Before you guys start bashing on Chinesium quality, I still haven't seen 1 case of these failing and there is A LOT of people running them.
I can point you to plenty of cases of BMR, UMI and Global West cracking and failing. Hotchkis is the only company that I haven't heard of any failures, but they were out of my price range.
I forgot to add on both cars I am running Hotchkiss ball joints.
Old May 15, 2015 | 11:15 AM
Rallye469's Avatar
I think I have the same set but haven't installed them.
They seem REALLY heavy.
I'm saving up for some TRZ's
-pete
Old Apr 13, 2021 | 08:59 AM
Stephen Brown's Avatar
Installed
I sent you a message about your battery cables...I have to move my alternator to the passenger side and I really like the way your engine bay looks. If you wouldn't mind me copying you I'd love to hear how you made your cables. Thanks!
matt506
Jun 10, 2019 05:24 PM
ReallyWildStuff
Jul 20, 2017 06:45 PM
p518
May 31, 2012 04:42 AM
GothamCity
Jan 20, 2009 01:55 PM
cisco88
May 27, 2008 03:12 PM
