Cutlass Carpet Sound Deadener / Underlayment?
Installing replacement carpet. ACC carpet offers standard jute backing already attached in certain OE spots. What did GM use between the floor and the carpet? Where is it available? I'm looking for OE fit and appearance.
Thanks.
Thanks.
When I redid my carpet, I had to scrape some mostly melted tar paper off the floorboards so I suspect that was the factory original stuff. I put the same stuff back on - likely got it from the same place I bought the carpet but this was 20 years ago so I don't really remember.
The jute backing is all the factory used. I'm not a fan of the tar based sound deadeners as I spent days removing it from a car floor on one of my projects. Other off brands like from home depot and loews will not stand up and ooze if place inside doors in southern states.
My current carpet is not original so I can't check on my own vehicle. ACC shows this material as being "commonly used" in all 60's - 80's. Or, should I use a product like Dynamat? ... although that's a tar-based deadener and heat shield.
https://www.accmats.com/commerce/197...Deadener/8434/
https://www.ebay.com/itm/25280219863...84.m1436.l2649
If your convertible is like mine, you might what to rethink going with the original jute. The heat coming up from the floorboards during the summer has been driving my wife nuts. I went ahead and spent the money for Dura-mat and Dura-liner to take care of that problem. She's in storage for the winter (the cutlass, not my wife). I plan on installing it this upcoming spring.
Thanks Chip. I remember back-in-the-day when this my was summer daily driver and there was heat from the firewall and around the tranny hump.
So are you replacing the carpet (which typically has standard jute affixed to certain spots on the back) and installing Dynamat between the floorboards and the carpet? Dura-liner too? (I only know Dura-liner used for truck beds.)
I would use a product like Dynamat and the jute backed carpet. The Dynamat will keep the rattles and vibration down, jute will quit anything the gets through. Whie you don't have to use Dynamat as their are cheaper alternatives. I like Damplifier Pro, but there are others. Do NOT use the stuff from Home Depot or Lowes. When shopping, also look at the foil thickness and not the just the total thinkness of the sheet.
As the late Robin Williams used to say "It's like putting gauze in front of a semi, and just saying come on through."
Wayne
As with any adhesive based product, the surface must be clean of debris or it wont stick well.
Check out this link, it might offer some help. I also here his products are good and he will not try to sell you more than you need.
https://www.sounddeadenershowdown.com/
Not finding an auto floor insulator by the name "Dura-mat" or "Dura-liner." Only this floor product >https://www.youtube.com/watch?v=fOwkwozG1ic
***CORRECTION***
My brain was not working normally this morning...sorry 'bout that
It's Dyna-mat and Dyna-liner
milesmonte
March 23rd, 2015 07:31 AM
