Crankshaft Gear Install Tool
Old June 3rd, 2017, 02:32 PM
gbledsoe3's Avatar
Ok, where do I find/buy a crankshaft gear installation tool?
gbledsoe3 is offline
Old June 3rd, 2017, 03:32 PM
If your talking about the timing gear, it should be a very snug slip fit. Take some emery cloth and go around the crank until its smooth, then tap it on with a hammer and a short piece of pipe.
oldcutlass is offline
Old June 3rd, 2017, 03:56 PM
gbledsoe3's Avatar
Thanks. It's my first time, gotta have a first for everything at some point. Yes, it's the timing gear on the my new Eagle crank. I was concerned about tapping it on, but I'll pull the key, clean up with emery cloth and then tap it on. Before I do though, I need to remember to put the crank spacer behind it since I'm installing a hydraulic roller and have the DMR camshaft thrust kit.
Just checked the Engine Service manual and sure enough, they show the crankshaft timing gear being tapped on.
Old June 3rd, 2017, 06:44 PM
You've done some awesome work on your car.
Old June 4th, 2017, 07:19 AM
Yeah, I was going to say that you can find the "tool" at your favorite hardware or plumbing supply store.
joe_padavano is offline
Old June 4th, 2017, 07:58 AM
"Necessity is the mother of invention"
Old June 4th, 2017, 10:27 AM
Actually, laziness is the mother of invention.
Old June 4th, 2017, 11:03 AM
Laziness is the father...
Old June 4th, 2017, 09:03 PM
Ozzie's Avatar
That looks a bit like a Chevy 6 cylinder.
Ozzie is offline
Old June 5th, 2017, 05:29 AM
gbledsoe3's Avatar
I pulled that picture from the Olds service manual in the L-6 engine section.
Magna86
May 23rd, 2016 04:33 AM
brown7373
April 19th, 2015 06:29 PM
71RadioflyerVista
June 28th, 2011 09:11 AM
greenslade
May 2nd, 2011 07:14 PM
smcurro
February 27th, 2009 09:27 AM
Quick Reply: Crankshaft Gear Install Tool
