Crankshaft Gear Install Tool
Old Jun 3, 2017 | 02:32 PM
gbledsoe3's Avatar
Ok, where do I find/buy a crankshaft gear installation tool?
Old Jun 3, 2017 | 03:32 PM
If your talking about the timing gear, it should be a very snug slip fit. Take some emery cloth and go around the crank until its smooth, then tap it on with a hammer and a short piece of pipe.
Old Jun 3, 2017 | 03:56 PM
gbledsoe3's Avatar
Thanks. It's my first time, gotta have a first for everything at some point. Yes, it's the timing gear on the my new Eagle crank. I was concerned about tapping it on, but I'll pull the key, clean up with emery cloth and then tap it on. Before I do though, I need to remember to put the crank spacer behind it since I'm installing a hydraulic roller and have the DMR camshaft thrust kit.
Just checked the Engine Service manual and sure enough, they show the crankshaft timing gear being tapped on.
Old Jun 3, 2017 | 06:44 PM
You've done some awesome work on your car.
Old Jun 4, 2017 | 07:19 AM
Yeah, I was going to say that you can find the "tool" at your favorite hardware or plumbing supply store.
Old Jun 4, 2017 | 07:58 AM
"Necessity is the mother of invention"
Old Jun 4, 2017 | 10:27 AM
Actually, laziness is the mother of invention.
Old Jun 4, 2017 | 11:03 AM
Laziness is the father...
Old Jun 4, 2017 | 09:03 PM
Ozzie's Avatar
That looks a bit like a Chevy 6 cylinder.
Old Jun 5, 2017 | 05:29 AM
gbledsoe3's Avatar
I pulled that picture from the Olds service manual in the L-6 engine section.
Magna86
May 23, 2016 04:33 AM
brown7373
Apr 19, 2015 06:29 PM
71RadioflyerVista
Jun 28, 2011 09:11 AM
greenslade
May 2, 2011 07:14 PM
smcurro
Feb 27, 2009 09:27 AM
