crack checker
Old Dec 12, 2008 | 01:18 PM
crack checker
A friend of mine just gave me a present he picked up in a pawn shop.
The batteries are dead in my camera so I'll have to describe it.
Metal box contains Horse shoe shaped electro magnet, plastic bottle of power, perfume type sprayer with powder in it. No directions [of course]
Box reads 'Crack Checker" and says " Be sure all parts are free of oil and debris before checking for cracks."
Apparantly you spray the powder and hold the electro magnet find cracks.
Is this some kind of mangaflux?
Any help would be appreciated.
Old Dec 12, 2008 | 01:19 PM
Oldsguy's Avatar
Past Administrator
I think maganflux uses a dye, not a powder.
Old Dec 12, 2008 | 01:59 PM
dan2286's Avatar
I believe it is called magnetic particle inspection. Is that powder magnetic?
Old Dec 12, 2008 | 02:06 PM
I think so
How do you make it work?
Old Dec 12, 2008 | 02:31 PM
dan2286's Avatar
I think you put the powder over the surface you want to check, go over the surface with the magnet. The powder will go to the cracks if their is any. I am not sure if you touch the surface with the magnet or hold it just over it.
Old Dec 12, 2008 | 05:53 PM
Danny Wiseley's Avatar
Power up your electromagnet and place the poles on each side of the suspect area. Then "puff" the iron filings onto the head (for example) you are testing. The filings will stand up at the site of the crack, and make it very visible.
Old Dec 13, 2008 | 11:41 AM
lshlsh2's Avatar
71 cutlass convertible
CAUTION! Keep out of the reach of plumbers
Old Dec 13, 2008 | 01:14 PM
Is that what it's for?
Checking for leaks in irom pipe?
Old Dec 13, 2008 | 01:33 PM
don71's Avatar
same but different
Ha Ha!! Hmm..he means, where ever there is a plumber near by they are usually cracking a smile.....from the back side Its not exclusive to plumbers, carpenters do it too, but they like suspenders so this kinda of thing does'nt happen. See where these threads go?
Hope you figure out the crack finder. And yes it could work on pipe too. Any metal thats magnetic.
Old Dec 13, 2008 | 03:26 PM
[QUOTEYes it could work on pipe too. Any metal thats magnetic.[/QUOTE]
It might not work too well on a cast surface such as a manifold or the combustion chambers. The surface of a sand casting will be too rough and prevent the filings from standing up on the edge of the crack. It is generally a better idea to use a dye penetrant such as Zyglo on a cast surface.
Old Dec 13, 2008 | 09:56 PM
I beg to differ. It works very well on a cast surface, rough or not.
Old Dec 14, 2008 | 10:54 AM
Ok. Regardless, it is still good for someone to know that there are multiple ways to test a block for cracks. Zyglo makes good dyes that can be used with or without a black light. Ultrasound is another way to test metal for fatigue and small cracks.
Charlie_brown
Mar 7, 2011 06:45 PM
OldsMotion
Feb 16, 2011 01:32 PM
malibu406
Feb 5, 2010 10:19 AM
my69olz
Oct 22, 2009 07:44 AM
Pitbull2o08
Jan 16, 2008 07:19 PM
