compression ration vs psi
Old Aug 15, 2015 | 07:59 PM
67Rocket's Avatar
Question for you physics majors. I recently checked the compression on the 68 455 engine I am installing. The readings for a cold block with all plugs removed and no carb on the intake were between 190 and 200 psi for each cylinder. How does PSI relate to CR? The engine has C heads with new valves and was bored .030, previous owner was not sure what pistons or head gaskets were used. Thanks to all
Old Aug 15, 2015 | 08:35 PM
It doesn't.
It relates to CR and cam profile and timing.
Without knowing the details of the cam, it is impossible to suggest an exact cranking compression number.
That being said, your numbers are normal for a '68 engine, and probably represent a high compression engine.
matchek
Aug 14, 2012 11:10 AM
at3reg98
Jun 8, 2012 07:02 PM
DENT
Feb 10, 2012 08:42 AM
coltsneckbob
Oct 14, 2010 04:05 PM
shaks 442 clone
Drivetrain/Differentials
Sep 4, 2007 08:30 AM
