cold start fast idle 93 3.4
Old Apr 30, 2019 | 05:15 PM
rhaberm's Avatar
93 cutlass supreme conv with 3.4 , cold start with fast idle then slows to normal tps ia or what could be problem?
any suggestions.
Thanks ,
Bob
Old Apr 30, 2019 | 11:42 PM
Schurkey's Avatar
Fast idle...and rough idle?
VERY common for the intake gaskets to fail--creates a vacuum leak.
'Course, the vacuum plumbing is brittle plastic and seems to shatter at the drop of a hat. Also causes vacuum leaks.
HOW FAST is this "fast idle"?
Old May 1, 2019 | 05:14 AM
Bob, is the fast idle after cold start normal? Without more details it sounds to be operating normally. Often, the 3.8l, 3.4l, etc. from the 90s would get improved drive ability after desludging the throttle body and IAC motor. If you haven't done this with plugs and wires recently it may be time for a tuneup.
n_holman
Oct 5, 2014 11:38 AM
AZ455
Nov 3, 2011 06:24 AM
Olds64
Aug 25, 2009 09:22 AM
68ragtop
Aug 24, 2008 09:44 AM
Chumley
Aug 9, 2008 08:02 AM
