Carb Rebuild / How often??
Old May 23, 2018 | 11:15 AM
Kensey's Avatar
Hi all, so how often do you rebuild your carb? Wait till there's an issue, or every few years as maintenance?
Thoughts?
Old May 23, 2018 | 11:20 AM
If it ain't broke, don't fix it.
Old May 23, 2018 | 11:43 AM
shiftbyear's Avatar
2x on what Eric said. Just make sure the hold down bolts and carb screws are snug, they can work loose over time. You didn't specify what kind of carb you had. Throttle shafts can wear into the aluminum base plate over time causing looseness and possibly vacuum leaks. This requires drilling and installing bushings.
Old May 23, 2018 | 11:47 AM
Run to Rund's Avatar
About every 30-50 years, new needle/seat depending on how bad the fuel attacks viton rubber. Snug the various screws holding the carb together every 10-20 years.
Old May 23, 2018 | 11:56 AM
Kensey's Avatar
These are the answers I wanted to hear!
I have a 72 Delta 88 with a 350/2bbl carb.
Seems to be just fine. But the car is new to me, so I don't know how long it's been.
A lot of my buddies have their carbs rebuild as part of their tune-up.
Old May 23, 2018 | 11:57 AM
Kensey's Avatar
I'm about to change all the plugs & wires, dist cap, rotor etc. Was gonna pull the carb, but it seems just fine.
Old May 23, 2018 | 12:18 PM
If your still using points, you need a tach/dwell meter, timing light, and a vacuum gauge to adjust everything after you get done changing parts.
Old May 24, 2018 | 09:24 PM
Ozzie's Avatar
I replace parts or rebuild components when they no longer perform correctly. Doing it prematurely just increases the cost of ownership unnecessarily.
Old May 26, 2018 | 07:45 AM
Bryan Burch's Avatar
Step 1: Throw it in the trash.
Step 2: Go EFI. Lots of options.
Step 3: Never look back.
Old May 26, 2018 | 07:50 AM
redoldsman's Avatar
Proud Viet Nam Veteran
If you just bought the car a good tune up is not a bad idea. I would not include the carb unless there is a problem. EFI is not for everybody. If you are only driving the car as a hobby, you will never recover the cost.
joe_padavano
May 31, 2017 05:29 AM
dal442
Jun 5, 2016 05:59 AM
chrisneu68olds
Oct 20, 2014 02:24 PM
chrisntam
Aug 20, 2013 05:39 PM
AZ455
Aug 30, 2011 08:50 PM
