a carb question - service vs original
I have a question:
can someone tell me what the differences are with a service replacement carb versus and original issue carb?
are the components the same? What about the numbers on the side? Are they coded differently?
thanks
tim
thanks
tim
The few service carbs that I've compared to OE did have different rods, jets, power piston spring, etc. If you can get me the numbers of the carbs you're looking at I may have the component parts breakdown. "Service" carbs are meant to be a usable (serviceable) replacement, not necessarily an exact duplication of the original.
Tim on 69 service replacement carbs that I have date codes are by carb ID number as opposed to being on base plate on original carbs
Also have seen 0's precede the ID numbers as well but don't know if that was a practice across the board or potential re-stamps
Cant speak on the internals
If the service replacement carb has the same part number as the original, then it should be built with the exact same parts.
The differences come in when GM changes the parts catalog to list a different part number carb as the service replacement. This is usually done to reduce the number of part numbers stocked.
Since both the carb's date code and part number include a digit for the year, it's easy to determine if a carb is a service replacement built after your car.
Also, in my experience, a service replacement carb won't have the two-letter "broadcast" code.
A service replacement carb has the part number of the original carb but the date code will be after the year indicated that the carb was used.
Randy C.
Randy C.
70Post
January 26th, 2020 09:44 PM
2blu442
December 28th, 2013 09:51 PM
69442murph
March 25th, 2013 07:59 AM
arodenhiser
December 30th, 2012 08:44 AM
holidaysedan
December 21st, 2010 07:48 AM
