a carb question - service vs original
Old Jul 16, 2014 | 07:15 AM
69442murph's Avatar
I have a question:
can someone tell me what the differences are with a service replacement carb versus and original issue carb?
are the components the same? What about the numbers on the side? Are they coded differently?
thanks
tim
Old Jul 16, 2014 | 07:23 AM
Service carbs may not have the same jets and rods that the predecessor had, they should though. Numbers will be coded differently, at least the date code will.
Old Jul 16, 2014 | 09:32 AM
frankr442's Avatar
The few service carbs that I've compared to OE did have different rods, jets, power piston spring, etc. If you can get me the numbers of the carbs you're looking at I may have the component parts breakdown. "Service" carbs are meant to be a usable (serviceable) replacement, not necessarily an exact duplication of the original.
Old Jul 16, 2014 | 09:36 AM
dnmfranco's Avatar
Tim on 69 service replacement carbs that I have date codes are by carb ID number as opposed to being on base plate on original carbs
Also have seen 0's precede the ID numbers as well but don't know if that was a practice across the board or potential re-stamps
Cant speak on the internals
Old Jul 16, 2014 | 03:58 PM
BlackGold's Avatar
If the service replacement carb has the same part number as the original, then it should be built with the exact same parts.
The differences come in when GM changes the parts catalog to list a different part number carb as the service replacement. This is usually done to reduce the number of part numbers stocked.
Since both the carb's date code and part number include a digit for the year, it's easy to determine if a carb is a service replacement built after your car.
Old Jul 16, 2014 | 07:55 PM
rcorrigan5's Avatar
Randy C.
Also, in my experience, a service replacement carb won't have the two-letter "broadcast" code.
A service replacement carb has the part number of the original carb but the date code will be after the year indicated that the carb was used.
Randy C.
70Post
Jan 26, 2020 09:44 PM
69442murph
Mar 25, 2013 07:59 AM
arodenhiser
Dec 30, 2012 08:44 AM
holidaysedan
Dec 21, 2010 07:48 AM
