Carb Problem
Old Dec 13, 2016 | 04:47 PM
Pfiffle's Avatar
Carb Problem
1976 Cutlass S 350. I just started my car after it was sitting for 8 years in my garage. I pumped out the old gas, put new in, squirted oil in each cylnider and primed the carb. It fired up on the 3rd try. Nice. Anyway, now the carb is pissin g fuel out of the brass plug shown in the picture below. What could be the reason and how can I fix it?
Thanks Tom
Old Dec 13, 2016 | 04:55 PM
My guess would be a stuck float or leaking needle and seat.
Old Dec 13, 2016 | 05:10 PM
Pfiffle's Avatar
It's a Holley by the way.
Old Dec 13, 2016 | 05:14 PM
Pfiffle's Avatar
Oldcutlass, do I have to rebuild it then? I have a Qjet ready for install but I just wanted to get it started.
Old Dec 13, 2016 | 05:43 PM
Quadrajet Power's Avatar
You may can pull the needle/seat and clean it for temporary fix. The Holley stuff doesn't sit well for long periods.
Old Dec 13, 2016 | 07:01 PM
There were 2 versions of that carb, square bore and spread bore. If you have the spread bore version then just swap carbs. Or, if you have an aftermarket manifold that accepts a spread bore then you can still swap carbs. Or you can take it apart, clean the needle and seat, check/adjust the float and put it back on.
D Appeldorn
Jun 14, 2008 11:47 PM
Pghstarsky
Apr 4, 2008 07:19 PM
1987supreme305
Jun 6, 2007 01:41 PM
Gee
Jan 27, 2005 04:57 AM
Gee
Cars Wanted
Jan 26, 2005 12:02 PM
