Cam Pin and Timing Chain Alignment
Old August 31st, 2014 | 10:33 AM
Freddy B's Avatar
I currently have my Olds 455 open to change the timing chain. I brought the #1 piston to TDC but the camshaft pin is at the 6 o'clock position. The cam pin hole in my new timing chain gear is at the 12 o' clock position when I align the dot with crank gear dot.
Will it be an issue if I turn the camshaft so the cam dowel pin is aligned with the new timing chain gear hole? Or will I have to change the camshaft as well?
Old August 31st, 2014 | 10:52 AM
Chebby engines are at TDC#1 when the two dots are next to one another.
Olds engines are at TDC#1 when the dots on both the cam and the crank sprockets are at 12:00 (straight up).
Old August 31st, 2014 | 11:19 AM
Freddy B's Avatar
Thanks Eric I will turn the timing gear dot to the 12 o'clock position. I already turned the crank to try and align the dots together will it be a problem if I turn back were it was?
Old August 31st, 2014 | 11:39 AM
No, just make sure that the rotor is in the right position when you try to start it, or coche no va, as they say south of the border.
Old September 2nd, 2014 | 10:47 AM
Seff's Avatar
Well, technically the gears will both be at 12 o'clock half the time, and the cam gear at 6 o'clock half the time. Whether "TDC" is defined as when the piston is at the top of the compression stroke only, or also when it's at the top of the exhaust stroke as well, is the question here.
Old September 2nd, 2014 | 12:19 PM
There's no question - TDC is defined as ANYTIME the piston is at the top of it's stroke. That's why you need to specify TDC on the compression stroke or TDC on the exhaust stroke.
Old September 2nd, 2014 | 12:21 PM
Seff's Avatar
Gotcha. Then installing the timing chain either way is fine, just means you might have to realign your distributor.
Old September 2nd, 2014 | 12:29 PM
Or rotate the crank one revolution...
Old September 3rd, 2014 | 09:26 AM
Seff's Avatar
That too. It's important that people understand the relationship between the different parts, though.
Stevec
February 8th, 2015 02:25 PM
fv64olds98
January 31st, 2013 03:56 PM
zodiacblueS
September 15th, 2011 10:42 PM
Tom442
May 31st, 2011 11:12 PM
442scotty
May 13th, 2009 06:42 PM
