a/c car with 342s
Old February 1st, 2014, 06:58 AM
NDERISE's Avatar
Question a/c car with 342s
is there anyone that has documentation of a 3.42 ratio diff. in an a/c car I have had this discussion with a few olds buffs but would like to see someone post a build sheet with the fact if possible to but the debate to rest. and does anyone know of car that were built that didn't match the build sheet
thanks ray
NDERISE is offline
Old February 1st, 2014, 07:05 PM
Gary M's Avatar
A/C limitations
The a/c compressors in most cars are good for 3000 RPM intermittent and if you use a gear ratio that exceeds that amount regularly, the compressor does not last long. You may find cars built as you are looking but if you are looking for an excuse to ignore the limitations of the A/C unit don't be surprised if you have to rebuild your A/C unit.
Gary M is offline
Old February 1st, 2014, 07:51 PM
NDERISE's Avatar
not for limitations
I know this may be the reason why olds didn't put the 3.42 units in cars with a/c only looking for documentation on the possibility of it happening. dealers would try to do anything to try to sell a car back in the day, they may have pulled strings to get a sale. I have spoken to people on the forum that have here of several car with 3.42 a/c cars. thanks for your reply. don't forget these cars (1970) had a comp. hold in relay)
thanks ray
NDERISE is offline
jjokrm
April 13th, 2013 08:26 AM
Dan Wirth
May 21st, 2012 11:30 AM
Joel
December 26th, 2010 07:52 PM
The Stickman
June 12th, 2010 10:27 PM
Quick Reply: a/c car with 342s
