bumper nuts and bolts 67 442
Anyone know what size nuts and bolts I need to mount the bumper to the frame I already have the bolts to mount the bumper to the brackets any help thanks
FYI,you need to use the OEM washers as they have teeth to grip the bracket/frame.
That's what I am looking for, front and rear I appreciate it
Hello Chris and welcome to CO.
There is a lot of good people here that will sometimes donate smaller parts just to see more of these Oldsmobiles get back out on the streets!
Some vendors to try when all else fails
AMK is a automotive hardware supplier
http://www.amkproducts.com/bulk1.asp
Fusick is a manufacture and seller of Olds parts
http://www.fusickautomotiveproducts....nts.asp?dept=1
Inline Tube is also a manufacture and seller of Olds parts
http://www.inlinetube.com/PDF%20cata...alog-index.htm
Or you can just measure the diameter of the hole, go to the local fastener house and get some GR8's for a whole lot less than $35 + freight. Get some strip calk to shove in your socket to somewhat hold the bolt when you go through the frame holes.
I agree it is pricey, I was just looking for factory specs on them I live next to a hardware store so access is not a problem its just having the righ ones
I would use the Year One units because you get nice finished parts as mine would be rusty and would need cleaning and refinishing. By the time I find them and get them shipped,you can already have them from Year One.
If you can get the parts from someone on the site, that would be great.
Maybe for the bolt and nut Eric, but that washer is special. In for a penny, in for a pound. The reproduction set is phosphate coated so it even looks stock going in. IMO it's worth the $ to go with it.
Tom442
July 25th, 2011 02:46 PM
