bumper nuts and bolts 67 442
Old Jun 19, 2014 | 08:51 AM
Oldser 1's Avatar
Oldser 1
Anyone know what size nuts and bolts I need to mount the bumper to the frame I already have the bolts to mount the bumper to the brackets any help thanks
Old Jun 19, 2014 | 09:00 AM
66-3X2 442's Avatar
I probably have the OEM bolts/nuts & washers if that is what you're looking for. I can get the correct amount from the PIM. Let me know if that's what you want
FYI,you need to use the OEM washers as they have teeth to grip the bracket/frame.
Old Jun 19, 2014 | 09:14 AM
Octania's Avatar
e.g.,
https://www.yearone.com/Product/1964-72-gto/kt655
Oldser 1's Avatar
Oldser 1
That's what I am looking for, front and rear I appreciate it
Old Jun 19, 2014 | 10:19 AM
ROCKET VAPOR's Avatar
Lance
Hello Chris and welcome to CO.
There is a lot of good people here that will sometimes donate smaller parts just to see more of these Oldsmobiles get back out on the streets!
Some vendors to try when all else fails
AMK is a automotive hardware supplier
http://www.amkproducts.com/bulk1.asp
Fusick is a manufacture and seller of Olds parts
http://www.fusickautomotiveproducts....nts.asp?dept=1
Inline Tube is also a manufacture and seller of Olds parts
http://www.inlinetube.com/PDF%20cata...alog-index.htm
Old Jun 19, 2014 | 10:54 AM
Good info for me too, as mine came with the bumper separate and the brackets AWOL. Got the brackets, but no bolts, etc, etc, so I'll be on those, too.
Old Jun 19, 2014 | 12:29 PM
Or you can just measure the diameter of the hole, go to the local fastener house and get some GR8's for a whole lot less than $35 + freight. Get some strip calk to shove in your socket to somewhat hold the bolt when you go through the frame holes.
Old Jun 19, 2014 | 01:37 PM
Oldser 1's Avatar
Oldser 1
I agree it is pricey, I was just looking for factory specs on them I live next to a hardware store so access is not a problem its just having the righ ones
Old Jun 19, 2014 | 03:52 PM
66-3X2 442's Avatar
I would use the Year One units because you get nice finished parts as mine would be rusty and would need cleaning and refinishing. By the time I find them and get them shipped,you can already have them from Year One.
Old Jun 19, 2014 | 07:25 PM
I bought new replacement bolt/nut/washer set from ILT and they were 100% perfect. It was for the rear bumper of my 72. There is absolutely NO parts crib in a hardware store that sells those washers with the teeth on them. And you don't want to use a simple lock washer because it just won't hold in place like it should. I don't know if the bolts are the same for 67, but here's a link to ILT's on line store showing the bolts/washers Bumper frame mount kit and it seems pretty reasonable for 22.00. If nothing else you can get a good look at what those 'tooth' washers look like.
If you can get the parts from someone on the site, that would be great.
Maybe for the bolt and nut Eric, but that washer is special. In for a penny, in for a pound. The reproduction set is phosphate coated so it even looks stock going in. IMO it's worth the $ to go with it.
nolabigdawg
Oct 25, 2014 11:50 AM
Oldser 1
Jun 18, 2014 02:42 PM
shamusj
Feb 11, 2014 02:16 PM
epinkston
Sep 26, 2013 08:48 AM
Tom442
Jul 25, 2011 02:46 PM
