Bumper bolts
Old Feb 16, 2020 | 01:12 PM
Cruiser Bob's Avatar
Bumper bolts
Getting the rear bumper on my 71 Vista Cruiser rechromed, got new bolts from Fusick all they have are capped bolts and they just do not look right to me, not like the regular uncapped ones they look too flat. What is everyone using for this.
thanks
Old Feb 16, 2020 | 02:52 PM
mrolds69's Avatar
Bob, at that time factory bolts were capped. There are like maybe 1/2 dozen different styles and sizes of repro bolts, The wrong size or style looks goofy. You can polish the caps to a very shiny finish.
Old Feb 18, 2020 | 02:41 PM
dennis_30281's Avatar
Take the caps off and have the bolts chromed. Those caps just set up the bolts for rusting anyway
Dennis
Old Feb 19, 2020 | 06:19 AM
When I took the brackets off there were 2 bolts appearing to be original , they are not capped and higher domed than the new capped bolts. Taking the caps off on the ones that were on the car all are elevator bolts with the cap making them domed. I should be getting the bumper back in a few weeks I will just see what the capped bolts look like on it.
Old Mar 1, 2021 | 06:46 AM
Jungle Cat's Avatar
Bob I made a post on the correct frame carriage head bolts. There is important information there. You should check it out. If your originals frame to bracket bolts are good have them phosphate plated and use originals. The problem is new ones don’t have the correct small square under the head and don’t allow you to adjust the bumper. This is an original next to a regular carriage head bolt. Look at the square under the head. That is the issue.
Old Mar 1, 2021 | 09:51 AM
Jungle Cat's Avatar
This is in lines offering. The squares under the head require grinding to work properly.
https://www.inlinetube.com/products/...waAroYEALw_wcB
Old Mar 1, 2021 | 10:07 AM
The capped heads are factory correct. The stainless caps don't rust. I would check the offerings at AMK.
https://www.amkproducts.com/wp-conte.../BULK_6-24.pdf
Old Mar 1, 2021 | 10:23 AM
Loaded68W34's Avatar
Do you have any pics of your vista? Who did you have do the bumpers? As Joe said, the stainless capped bolts are correct. As far as I know the "high dome" chromed bolts were not used after 65 .(someone here can correct me if I am wrong as they may have been used up to 67)
Old Mar 1, 2021 | 10:26 AM
Something like this?
https://www.amkproducts.com/product/b-12758/
Old Mar 1, 2021 | 10:28 AM
Here's another source.
https://www.clipsandfasteners.com/bumper-bolts-s/55.htm
Old Mar 1, 2021 | 03:11 PM
briane's Avatar
I believe these may match the original profile and diameter, at least for my '69 and '70 Cutlass and Chevelle. I have some NOS, correct part number bolts. Recently I bought some from AMK and found the profile was correct but the outside diameter was a bit large. I haven't actually purchased these Midwest Musclecar bolts yet, but of all the ones available I think these are the most promising:
https://www.ebay.com/itm/GM-Camaro-F...gAAOSwk0tdLUG5
T.Wong
May 23, 2018 10:27 AM
Oldser 1
Jun 19, 2014 07:25 PM
hialeah56
Feb 23, 2011 03:47 PM
Maccabeus
Dec 1, 2007 06:50 PM
tarheeldoc
Oct 23, 2007 11:01 AM
