Borg Clock stem removal help ??
Clock Stem removal help ??
Hi All - trying to change the faceplate in a Borg clock from a 1971 Cutlass. Cannot, for the life of me, get the stem to unscrew .
Can someone please tell me if the little knurled **** is the thing that unscrews from the shaft after pulling up the plastic sleeve to reveal the metal shaft - OR, does the shaft itself unscrew from the gear inside ?
Or..maybe something else entirely.
I don't want to break the thing off, so, before I put brute strength on it, I'd like to find out what part actually unscrews...and, maybe it is a left or right hand threading ??
Thanks..
Joe - New Jersey
Thanks..
Joe - New Jersey
Hi All - trying to remove the stem from the clock on a 1971 Cutlass but cannot, for the life of me, get the thing to unscrew.
Can someone please tell me if it is the little knurled **** that unscrews, or the shaft itself from the gear inside the movement.
I have tried to turn the knurled **** while holding the metal shaft with needle nose pliers after sliding the plastic sleeve down to reveal the shaft, but no joy.
I'd like to get it off, but before I apply brute strength to it, would like to know what part actually unscrews, and maybe if it is a left hand or right hand threading ?
Joe - New Jersey
Joe - New Jersey
**** comes off. Check and see if there is a little slot in the center for a flat head. Some are like that. Don't turn the ****, undo the little screw in the center of the ****, if it has it. Think eyeglasses screwdriver size.
^^^This. You need a jeweler's flat blade screwdriver. The "screw" is actually a tiny tubular nut that screws over the end of the clock shaft. Once the screw is loose, the **** pulls off. This photo is Chevelle, but you get the idea.
I've seen several other brands that have the small screw in the middle of the **** but the Oldsmobile ***** are not like that. I have had many that are really stubborn to the point of me thinking I would break the stem if I turned the **** any harder. I have found that if you take a really small set of pliers & grab the stem just under the **** & then use a small torch/lighter to heat up the **** for about 15 seconds or so & then use another small set of pliers to gently turn the **** they almost always come loose.
