belts
Old Sep 26, 2020 | 06:05 PM
jfb's Avatar
jfb
belts
aluminum pulleys is what i have. which auto store todaz sells belts that fit n''''a belts are now to wide as of this year. which belts also last.
Old Sep 27, 2020 | 08:47 AM
jfb's Avatar
jfb
these are v belts all of us need a update on parts returning and wasting time plus cost never reallz works out.
Old Sep 27, 2020 | 08:58 AM
I like Gates. Measure the lengths you need with a string, take that/those measurement/s and the water pump pulley with you to the parts store and get the ones that fit the pulley and that length/s.
Old Sep 27, 2020 | 11:44 AM
jfb's Avatar
jfb
my problem is which store I work for a shop but we mostly have the serpentine. napas belts as of this year do not sit in the aluminum pulleys correctly even when dead tight with no movement and I tried all different tension points. the napa belts seem to be to wide I need them about a eight thinner. do you have a proven store that sells the right widths? I might have to rely on swap meets for nos belts otherwise.
Old Sep 27, 2020 | 01:05 PM
Belts are not supposed to be bottomed out in the shiv.
Old Sep 27, 2020 | 03:14 PM
NAPA belts are made by one of the major manufacturers, so they should be the same as belts you find with a name brand on the package.
If the belts really are too narrow, look at a manufacturer's site such as Gates for the dimension specs for the belts and look for one that is wider.
Old Sep 27, 2020 | 04:05 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Try either Gates, which make Napa belts, there is a difference of design between the the two. Another to try is the Dayco Top Cog belts. I find they both stretch a ton, I need to go a size or two smaller than recommended due to stretch.
olds 307 and 403
Oct 10, 2016 07:07 PM
steverw
Aug 18, 2015 05:32 PM
Sircajun
Jun 16, 2014 02:34 PM
archeryshooter
Apr 2, 2011 05:48 PM
stevengerard
Sep 26, 2009 08:59 AM
