ATF or Power steering Fluid????
I have a 1969 Oldsmobile 442. Replacing my leaking steer shaft seal in my gear box tomorrow. Ive used power steering fluid since 'Ive had the car the past 5 years. What is recommended? or what is bette?,Atf or power steering fluid? Like I said I've been using power steering fluid for this long, should I stick with it?
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Just my luck
Thanks for all your input. I attempted to replace my steer shaft seal in the gear box. Old one came out great. New one pressed in wonderful. Guess what????? The junk still leaks just as bad if not worse. I'm feed up with it. Blowin $100.00 bucks this week on a remanufactured one so I can just be done with it.
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
