ATF or Power steering Fluid????
Old May 5, 2011 | 07:29 PM
1969cutlazz's Avatar
I have a 1969 Oldsmobile 442. Replacing my leaking steer shaft seal in my gear box tomorrow. Ive used power steering fluid since 'Ive had the car the past 5 years. What is recommended? or what is bette?,Atf or power steering fluid? Like I said I've been using power steering fluid for this long, should I stick with it?
Old May 5, 2011 | 07:51 PM
OLD SKL 69's Avatar
GM Enthusiast
When I replaced the steering boxes in my 63 Riv and 71 Cutlass, I flushed and refilled with power steering fluid. Been 10 years with the Riv and 1 with the Cutlass with no problems.
Old May 6, 2011 | 04:09 PM
jag1886's Avatar
I used power steering fluid in my 65 when I flushed it, works great!
Old May 7, 2011 | 09:57 PM
Just my luck
Thanks for all your input. I attempted to replace my steer shaft seal in the gear box. Old one came out great. New one pressed in wonderful. Guess what????? The junk still leaks just as bad if not worse. I'm feed up with it. Blowin $100.00 bucks this week on a remanufactured one so I can just be done with it.
Old May 8, 2011 | 03:04 AM
jensenracing77's Avatar
same thing happened to me. the shaft looked good and all but it leaked worse. i just figured i must have cut the seal putting it in. i said heck with it and got another box also.
SavedbyHim
Aug 10, 2014 08:13 PM
Greg Rogers
Aug 17, 2013 07:10 PM
craftsman1956
Sep 2, 2010 07:46 AM
F-85 4-4-2
Sep 10, 2009 02:58 PM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
