approx value 66 442
Old July 4th, 2018, 08:48 AM
goatman73's Avatar
approx value 66 442
hi, was wondering as to the approx value of a mostly surviver num match solid 66 442.has ps,pb,ac,tach,vac gauge,pw,4-sp with console,posi,am/fm w rear speaker,vac trunk release.pwr ant,rear defog,dealer add on tri power.73k orig miles,i think paint has been touched up or could have been repainted way back,am contemplating selling so was wondering as to value thanks.
goatman73 is offline
Old July 4th, 2018, 08:56 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I don't know what it is worth but it sure is a nice car. I love 66 and 67's and that one is the perfect color and a 4-speed. Go to hagerty.com to get an idea of value.
redoldsman is online now
Old July 4th, 2018, 11:35 AM
I'd like to see the numbers that "match", considering that Olds didn't start stamping the block and trans with a VIN derivative until the 1968 model year.
joe_padavano is offline
Old July 4th, 2018, 11:41 AM
jcdynamic88's Avatar
i'd say about 10k,when can i pick it up?
jcdynamic88 is offline
Old July 4th, 2018, 01:11 PM
RandyS's Avatar
If you can post some more pics we can give you a better idea of it's potential worth. Min 20K as it shows.
RandyS is offline
Old July 4th, 2018, 02:21 PM
m371961's Avatar
Very sweet with a lot of options. Maybe I am just old school but I always liked these more then later ones.
m371961 is offline
Old July 4th, 2018, 09:41 PM
I usually go with the Old Car Price Guide's numbers. I would call that a strong condition 3 car. Stick and tripower will help. Documentation showing dealer added tripower and the protectoplate will help.
For numbers, like Joe said, if you look at the front of the right head it should have a number stamped into the pad which will match the protectoplate. If you dont have the plate, then you can be sure it is A correct engine and transmission and if you know the car for a long time, the correct engine, etc.
Koda is online now
Old July 5th, 2018, 12:03 AM
Rocket Renegade!
Hard to really tell about condition -- need more pictures. Could be a good #2 car.
With regard to the numbers, I understood Joe to say that there are no numbers to match, as Olds didn't start stamping engines and transmissions with VIN derivatives until '68 and thus original engine/transmission status cannot be determined. I had always thought this was the case -- am I reading wrong or misunderstanding?
BangScreech4-4-2 is offline
Old July 5th, 2018, 04:49 AM
This is true, unless you have the protectoplate with the engine serial number on it still, then you compare it to the engine serial on the front of the right head.
Koda is online now
Old July 5th, 2018, 05:12 AM
35tac's Avatar
Very nice car. More pictures would help. Like to see the cowl plate for sure. Vin tag also.
Wayne
35tac is offline
66-3X2 442's Avatar
There could be an engine ID # on paperwork if any. My 66 window sticker does not have any any ID info but the invoice does.
66-3X2 442 is online now
Old July 5th, 2018, 09:15 AM
Amazingjason's Avatar
Where are you located?
Jason
Amazingjason is offline
Old July 5th, 2018, 05:51 PM
goatman73's Avatar
thanks for the input. am located in az thanks.
Old July 5th, 2018, 09:31 PM
This is the closest that I’ve seen recently. It sold to one of the high bidders after the auction, I assume for slightly over $26,000. It is also well equipped, but has fewer miles and appears to be in better cosmetic condition.
https://bringatrailer.com/listing/1966-oldsmobile-442/
What price did you have in mind? I’m in central CA and have had my eye out for a nice 442 since I drove Mom’s 66 Cutlass through college.
Jason
4-Speed
June 4th, 2012 07:10 PM
mike's88
February 7th, 2012 07:59 AM
TripDeuces
August 18th, 2011 05:51 AM
zed
January 17th, 2010 02:50 PM
Quick Reply: approx value 66 442
