Any tips to eliminate cowl squeak?
Old Jul 11, 2016 | 09:46 AM
cfair's Avatar
On my 66 98 convertible, I've developed a nasty cowl squeak that happens mostly when the car is cold.
I know the problem is coming from the cowl cover (on the outside, behind the hood), but it presents as a dash squeak. It's driving me nuts.
I've greased the rubber shim, shot silicone spray all over the edges, tried isolating the cover with closed cell foam and tried isolating the cover edges with vinyl tape.
So far, the only fix has been removing it. Which isn't a fix.
Any ideas?
Thanks in advance,
cf
Old Jul 11, 2016 | 09:58 AM
Eddie Hansen's Avatar
funny enough, I was changing my lower window channel and noticed there is a support brace that basically supports the dash panel, window channel which is attached to the cowl, this is not welded on, but there is a cushion type foam tape? that separates it from the dash board, mine was in bits, and there was probably metal to metal squeaking there, I would have a look up under the dash, below the window to see if you have the same? I only saw mine as I removed the insulation etc, just a thought. you might be able to put some type of insulator even double faced foam tape if you can gget there abnd if that is the problem, I don't know just trying to help
Old Jul 11, 2016 | 12:35 PM
cfair's Avatar
Foam inserts
My 66 98 and Starfire has one on either side. Crushed to dust. I'll remake using one as a pattern.
Old Jul 12, 2016 | 05:39 AM
x2
My 2011 Ford Flex squeaked like crazy when we first bought it (less than 100 miles on it). It turns out there is a TSB to install the dash using foam tape. Once we had the TSB done it never squeaked again.
deadeyejedi
Apr 8, 2015 02:35 PM
ksukasiose
Sep 17, 2014 06:07 AM
Seff
Suspension & Handling
Feb 3, 2014 01:57 PM
rcdynamic88
Aug 29, 2013 12:46 PM
Want-A-Vert
Mar 7, 2007 05:37 AM
