After market radio
After market radio
Has anyone installed an after market radio that requires not alterations. The radio that came with the car had the dash altered and it was a such a butchered job that had to get another dash. I dont want to alter this one. any suggestion on an aftermarket radio that will fit into the dash would be most helpful
http://www.retrosoundusa.com/search?...=30&commit.y=9
these guys have some and Ive seen others in maybe it was the OPGI catalog ???
The Retro Sound one is my choice. I think a few members installed them without any big problems... I like the fact that you can use SD cards and it will random play songs within.
Custom auto sound has had quite a few quality complaints and the USB reader would not random play.
Regardless of your choice, the power output will only be about 10 watts or less per channel, regardless of claims of 200W... An external amp will always help.
Retrosound in my car from previous owner. Looks like an old (not original) radio with the power off and then the digital display comes through when you turn it on. Just using kick panel speakers with no amp so sound is only OK, esp with the top down. Never used the usb port, wish if was for an ipod instead.
yeah, i'm gonna have to find a new dash for my '60 88 too for that same reason! it sucks because the rest of the dash is like perfect but they cut it up to install the radio (which isnt even in the car anymore so i have nothing and not to mention there was already a place set up in the glovebox for an aftermarket radio) i dont understand why some people treat their classic cars the way they do :/
Here's one still made new and designed to fit the shaft-style openings. Plays cassettes and not CDs, but you can't fit a CD through the opening on one of these, anyway. It doesn't have a USB port, but it does have an aux input jack for your ipod or whatever.
Only $50.
http://www.crutchfield.com/p_070XC41...0.html?tp=5684
Only $50.
I had a 1970 am/fm radio converted to digital internals. It works great and even allows my ipod to plug in. But it's appearance and functions, including all the preset buttons appear and work as they do on a stock radio.
Definitely the best option if stock appearance is important.
Search for W70442 here on Classicolds. He reproduces the 8 - track housing. Randy does nice work. He made one for me and I installed a modern aftermarket radio in the housing. I had him to recess the radio mounting plate back about 2 inches from the front of the housing. I made a cover from a stock player that is removable. With the cover installed it looks almost stock, remove cover and you can access radio.
Another option I have thought about but have not researched is to just mount an amp under the seat and play an MP3 player directly through the amp. Sounds to easy for it to actually work.
Don W
Don W
