AC Delco PF45 oil filter
Old August 10th, 2022, 08:55 PM
Oldsdruid
rocketraider's Avatar
I have four of these filters new in the box and cannot for my life remember what they fit. I think 307 which means I've had them 25 years or longer, since last 307 car I had got totaled in Sept 97.
ACD has consolidated this part # several times so the online application guides and cross-references are less than useless. Anyone know what they fit?
rocketraider is offline
Old August 11th, 2022, 04:37 AM
newmexguy's Avatar
Yes believe they are 307 Olds. Was working at a Bridgestone/Firestone back thirty years ago, and recalled quite a few vehicles with the small Olds, that took that filter, as I recall.
newmexguy is offline
Old August 11th, 2022, 06:04 AM
69HO43's Avatar
You got it. 1978-1989 260/307/350/403 Olds V8 and 350 Olds Diesel plus some late 70s', early 80s Caddys, 425, 4.1 and 368. GM p/n 25010324. They're the "skinnier" filters than the 77 and earlier. The gasket runs right around the outer edge of the filter. The can is smaller diameter than your typical Olds filter. I think it got superseded about 25 years ago by the PF58, then to PF61, PF61E, PF61F. We all know the laters versions aren't all that and a bag of chips.
69HO43 is offline
Old August 11th, 2022, 07:36 AM
I'll add that while you CAN install an earlier large-diameter filter on the later V8s, the trans cooler lines need to be bent a little to clear. I did this on one of my 307s when I didn't have a small diameter filter to install.
joe_padavano is offline
Old August 11th, 2022, 07:56 AM
Oldsdruid
Many thanks!😺😎
Bigmikey65
December 8th, 2021 09:13 PM
GoodOldsGuyDougie
September 13th, 2016 11:49 AM
bulldog
March 6th, 2013 03:20 PM
mmurphy77
March 27th, 2011 06:22 PM
bittersweet71
February 25th, 2010 12:02 PM
Quick Reply: AC Delco PF45 oil filter
