AC Conversion Thread???
Old May 3, 2019 | 05:54 PM
Kensey's Avatar
Hi all,
I seem to remember a thread on here about converting your AC system to the new gas, but I can't find it???
Anyone have it booked marked and wouldn't mind replying with a link??
OR is it more realistic to go with a new vintage air system?
Thoughts?
Thanks,
Kensey
Pittsburgh, PA
Old May 3, 2019 | 06:44 PM
There is a sticky on calibrating the POA valve for 134A. Other than the conversion kit with the new valves, that’s all you really need.
Old May 6, 2019 | 03:22 AM
chip-powell's Avatar
If you do a search on POA valves, you would see a ton of info.
Personally, I found it cheaper to replace most my a/c components than to convert to Vintage Air. But it might be different in your area. I wound up replacing my compressor and clutch, evaporator, drier, O rings and the POA valve to convert. Total cost for the parts was about $300 (it was 2 years ago and prices will change). I chose a cycling switch instead of a new POA to keep the costs down, but so far I have had no issues.
Old May 6, 2019 | 11:13 AM
Kensey, I would suggest going to a Vintage Air system. I ditched the compressor and lines on my 71 98. I hate the look of the OE suction throttling valve systems. I much prefer the neat look of an orifice tube system.
I did use r152a (computer air duster) in the AC system of my 86 f250 as a sustitute for r12. It worked for 1 year but when I recharged it again it didn't work. You can Google YouTube videos on this work around. Of course, it's illegal, but to each his own.
TomT
Aug 30, 2017 09:45 AM
72hardtop
Jun 6, 2017 07:48 PM
rand5204
Oct 22, 2016 06:08 AM
72allblackcoupe
Apr 7, 2014 07:52 AM
1970-W30
Apr 2, 2013 06:21 PM
