!966 442 Really???
Old Jan 8, 2012 | 12:58 PM
patmills's Avatar
442forsure
!966 442 Really???
Have a look at this car advertised in Hemmings? Column shift automatic and hood moulding? I have never seen these two items on a '66 442.
http://www.hemmings.com/classifieds/...42/953989.html
Pat Mills
Old Jan 8, 2012 | 01:06 PM
2blu442's Avatar
Pat, I haven't seen you post in a while. Welcome back I hope all is well with you. John
Old Jan 8, 2012 | 01:12 PM
patmills's Avatar
442forsure
All is well thanks John. Still want to get down your way sometime. Love your '68.
Pat
Old Jan 8, 2012 | 01:17 PM
Pat Mills
No photos of the Fisher Body Data Plate, so no way to know if it's real or a Faux-Four-Two. The column shift AT WAS factory offered, even with bucket seats. In fact, if you ordered the AT option you got the column shift. You had to pay extra for the console and floor shifter. Obviously the hood chrome is incorrect, but that could be a replacement hood. Again, the cowl tag will tell.
Old Jan 8, 2012 | 01:20 PM
66-3X2 442's Avatar
Pat Mills
The column shift automatic was common and the hood could have been changed @ some point in time. If you ordered an auto 442 and didn't specify a floor mounted shifter,that's what you got.
Old Jan 8, 2012 | 01:24 PM
patmills's Avatar
442forsure
Thanks for the information. I like the hood moulding - wish they hadn't left it off the car.
Pat
Old Jan 8, 2012 | 01:41 PM
ferndaleflyer's Avatar
I have a column shift 442 w/buckets and no console. I don't think that front seat is correct an neither are the wheels----if that isn't a 442 someone went to a lot of trouble to change what they did and not either weld up the holes in the hood or find the right one. Looks like my car on the outside (except for the hood)
Old Jan 8, 2012 | 02:02 PM
Run to Rund's Avatar
It has the wrong trunk molding, and a 67 442 dash plaque. It has the stick shift open air cleaner. If the L78 442 option was "owner installed" as is almost certain, it was not done correctly with all necessary parts of the "option."
Old Jan 8, 2012 | 02:17 PM
66-3X2 442's Avatar
Looks like the cleaner bottom is chrome and would not be correct. I would guess this car is not a 442 but then again,unless the cowl tag says so,I would think clone or a bad job of restoring a 442. I didn't look @ all of the pictures but Dad nailed it,way to go Dad.
Old Jan 8, 2012 | 02:38 PM
I noticed the dash plaque, trunck molding, and the air cleaner after I made the post----probably not a 442
Old Jan 8, 2012 | 04:59 PM
Rickman48's Avatar
Then there's the 'mystery motor', painted black!!
Old Jan 8, 2012 | 06:20 PM
jensenracing77's Avatar
didn't the open element air cleaner only come on 4 speed cars? maybe i am way off on this? anyone know the correct application for the air cleaners on 67 442s?
Old Jan 8, 2012 | 06:33 PM
66-3X2 442's Avatar
That's correct,open element cleaners only on standard shift 442's. Even the 3 speed 442's had the open element cleaner.
harascho
Sep 28, 2015 12:33 PM
capstoneclub
Jul 11, 2015 04:28 PM
agpilot442
Mar 2, 2015 04:23 PM
allyolds68
Nov 29, 2014 12:10 PM
67 Cutlass Freak
Apr 14, 2011 09:26 PM
