72 Cutlass Supreme value , needs restoration .
Old Oct 8, 2023 | 06:30 AM
oldsguybry's Avatar
NOVICE car nut
Just curious because I just can't seem to get an idea what a ballpark figure would be on this car . It's not original as far as the drive train is concerned . It needs sheet metal work - rear quarters , roof , fender patches , and some floor pan areas . Good points - It has a 455 from a 68 Toronado ( somewhat fresh rebuild ) and will have a rebuilt transmission installed next summer and the frame is solid .
Old Oct 8, 2023 | 06:40 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I am not sure what the question is but it honestly sounds like you need to find another car. If it requires that much sheet metal work, you really don't have much of a body with that car.
Old Oct 8, 2023 | 06:42 AM
70W-32's Avatar
With out pictures, it sounds like a parts car
Old Oct 8, 2023 | 06:56 AM
oldsguybry's Avatar
NOVICE car nut
it needs sheet metal work , not complete replacement . Ill post some pictures
With all due respect .... I see a lot of project cars bought on here that need work , so you mean a 50 year old car is a parts car because it needs some sheet metal work ?
Old Oct 8, 2023 | 07:57 AM
oldsguybry's Avatar
NOVICE car nut
Old Oct 8, 2023 | 07:58 AM
oldsguybry's Avatar
NOVICE car nut
Interior is trashed except dashboard . Let me know if I need any other pictures or information I need to post
Old Oct 8, 2023 | 09:10 AM
Probably $3-5k with all the work needed.
Old Oct 8, 2023 | 09:53 AM
oldsguybry's Avatar
NOVICE car nut
That's around what I figured . It's probably closer to the lower end of that figure . I wish I never had to move it from the parking garage I had it in for all those years . That's when everything started going down hill . I have a cover for it at least to keep all the leaves off it.
Old Oct 8, 2023 | 11:31 AM
Oldsguy's Avatar
Past Administrator
You can do it, go for it.
Old Oct 8, 2023 | 04:19 PM
I think that's a decent number....
Certainly not all that bad honestly.
QUESTIONS:
(1) AC? If so, factory?
(2) Electric Windows?
(3) Electric Door Locks?
(4) Floor pans - good shape?
(5) Which transmission is currently in the car? TH350/TH400?
Intact dashboard which isn't trashed is a positive. Fresh 455 rebuild another positive. Solid frame is a positive.
Old Oct 8, 2023 | 05:04 PM
oldsguybry's Avatar
NOVICE car nut
The car came with AC but took all that out when I installed the 455 . Manual windows and locks . Floor needs repair on drivers side area . The car had a T350 that was from speed shop , but the torque converter ground splines off of shaft . I was going to put a different transmission in next summer hopefully
blakes7
Jul 21, 2023 12:57 PM
bigin1978
Jan 2, 2023 10:07 PM
rn_mccy
Aug 3, 2015 09:04 AM
John Hancock
Aug 12, 2012 11:02 AM
