72 CS Carb
Old Feb 9, 2020 | 06:39 AM
Apollo's Avatar
72 CS Carb
Hello,
I have a stock 350 4bbl Quadrajet in my 1972 cutlass supreme, Can somebody tell me what the CFM is? I need a replacement.
Old Feb 9, 2020 | 06:54 AM
It is a 750 CFM carb, but be aware that this is a air valve secondary carb that regulates actual airflow based on actual engine needs. Frankly, you will be much better off getting a proper rebuild on the original carb than trying to adapt an aftermarket one.
Old Feb 9, 2020 | 07:09 AM
Apollo's Avatar
Joe, will an 800cfm fit ?
Old Feb 9, 2020 | 07:14 AM
Go back and read what I wrote about how the Qjet limits airflow to only what the engine needs.
Can you bolt an 800 CFM carb onto an Olds 350? Sure. Will it run right? Well, tell us what has been done to the motor, what intake, what cam, and how you plan to use the car. Oh, and WHAT "800 CFM" carb?
Old Feb 9, 2020 | 11:54 AM
Apollo's Avatar
Joe, you were right, I bought the wrong carb. I found the duplicate rebuild at UREMCO . URM 11 1198. I don't fix em, I just drive em. Thanks Joe !!
Old Feb 9, 2020 | 02:06 PM
dragline's Avatar
It is usually better to have the original carb rebuilt, the linkage, fuel line and other hookups will match perfectly. 750 CFM is more than enough for a 350 Olds. Check out Everyday Performance for a rebuild. I've only heard good reviews about them. The URM 11 1198 is a great value, I can't believe they can reman so cheaply. I'd be curious to inspect their work.
https://www.summitracing.com/parts/urm-11-1198/
Old Feb 9, 2020 | 02:14 PM
When I buy a reman carb I prefer to get it locally for the many warranty trips it sometimes causes until I get one that works.
Old Feb 9, 2020 | 06:45 PM
That was my experience when I bought a reman QJet carb 10 years ago. Many trips back to the auto parts store for replacements due to sometimes obvious issues (such as a visible crack across the floor of the float bowl), then eventually for a refund, all to start over at a different vendor. I finally got a carb that worked and even had the correct jets, metering rods, hanger, and stampings. It was a win but took a while to get there.
Roger60
Oct 21, 2019 07:50 AM
kevdog442
Mar 4, 2016 03:27 PM
running4kicks
Feb 10, 2016 12:05 AM
old44272
Jan 29, 2014 06:55 PM
tru-blue 442
Apr 20, 2013 02:48 PM
