71 442 color question
I have decoded the cowl tag tells the strip color?
The color # is 49 B which the decoder says is Antique Jade with Black Vinyl or Convertible top. The car is a convertible (so does that mean the correct convertible top is black? The car has the hood induction system with white strips and white strips on the sides. It has buckets seats in jade green, which the cowl decoder says is correct. Are the white strips correct? It would seem odd to have a super dark green body with black strips (if they are to match the black top. (The car now has a white top, I believe it was changed)
thanks
greenandwhite71442
thanks
greenandwhite71442
The "stripe" color won't be indicated on the data plate. It can be found in a build sheet or whatever Olds put under the seat, carpet, or ??? although there's no saying whether your car still has that document.
You know the stripes don't have to match the top or interior, right?
RAMBOW
December 7th, 2017 07:22 PM
