71 442 body plate decode
Old Jun 17, 2016 | 10:19 PM
44blue's Avatar
I have a 71 442 from the fremont plant. the 455 motor is original to the car, the last 6 numbers of the vin correspond to the block, but it does not appear to be a w30, (from what i have read in the year one catalog ) but just a regular 455. but the body plate is a mystery to me. can anybody tell me what these numbers translate to.
ST 71-34487 z 00361 BDY
TR 943 B80 26 26 PNT
01A 033806 460506
thanks in advance,
neal
Old Jun 18, 2016 | 06:12 AM
01A 033806 460506
thanks in advance,
neal
ST71 = 1971 model year
34487 = Oldsmobile Division, 442 model line, Holiday Coupe body style
z = Fremont, CA assembly plant (which means the car CANNOT be a W-30, since W-30s were only built in the Lansing, MI assembly plant)
00361 = Fisher Body sequential assembly number
TR 943 = Trim code (don't have that with me at the moment)
26 26 PNT = Viking Blue Poly lower (first number) and upper (second number) body color
01A = built the first week (A) in January (01), 1971
033806 460506 = codes unique to the Fremont plant
Old Jun 18, 2016 | 07:55 AM
44blue's Avatar
aha! lansing only for the w30's. I didn't know that. It was not sold to me as a w30 so i already knew, it was just a 455. I checked the heads and the letter on them (E) and my year one catalog says those are 1970 heads. I wonder if the original heads got lost along the way or maybe at the factory they had some leftovers from the previous year. Anyway the block is original at least. Did Olds hide build sheets somewhere in the car that could tell me more about the options. I read somewhere that 442s didn't come with power brakes, but mine did, as well as power steering.
neal
Old Jun 18, 2016 | 12:52 PM
jaunty75's Avatar
B80 = roof drip molding
Old Jun 18, 2016 | 09:28 PM
They did not carry over the heads from 1970 to use on the '71 model year, so your heads are not original to your car. On Fremont built cars there is frequently a build sheet on top of the gas tank, which will have to be drained and dropped to check.
Old Jun 18, 2016 | 09:46 PM
2blu442's Avatar
Welcome to the site Neal. Please post some pictures of your car when you have time. I'm down in Medford, we've got a couple members in the Eugene area. Then Larry is over in Bend/Redmond. Let us know if we can help with anything related to your car. John
Old Jun 19, 2016 | 07:36 AM
44blue's Avatar
bummer. original heads must have walked away sometime in the last 45 years. I suppose i could go find some 71 heads if it bugs me too much. Does anybody know if u can tell if the tranny is original to the car?
neal
Old Jun 19, 2016 | 07:51 AM
The trans will have a vin derivative on the drivers side, and you should have an "OG" tag attached, wipe this tag with a rag if it is greasy or gunked up, do not use a screwdriver or steel wool to clean it as you will damage it, removing info.
Old Jun 19, 2016 | 09:17 AM
rcorrigan5's Avatar
Randy C.
TR 943 = interior color and front seat type = blue interior with a bench seat.
Randy C.
Old Jun 19, 2016 | 03:11 PM
2blu442's Avatar
If your car has an automatic transmission here's an old thread with locations for the vin derivative. Your car should have had a TH400 if auto.
https://classicoldsmobile.com/forums...-original.html
If its a four speed it will still have the number stamped into the drivers side of the gearbox. Let us know if it is and we'll try to describe or locate pictures of its location.
The 1971 455 G heads are common so if you decide to change out the E heads there's several of us here who can provide the correct castings for you.
John
Old Jun 19, 2016 | 03:18 PM
2blu442's Avatar
Neal, I just recognized your car. I saw that on Craigslist back in 2010 as a project car for sale. Have you been able to re-assemble the car? Did you buy it from the sellers in 2010 or someone else more recently?
John
jaunty75
44
Oct 14, 2014 02:16 PM
rogerr
Oct 6, 2013 01:26 PM
x2248344
Aug 10, 2012 04:18 AM
virtualwsp
Aug 10, 2011 01:54 PM
rida142
Sep 3, 2007 02:33 AM
