70-72 OAI Air Filter housing ID
How do you identify a Factory OAI air filter housing(not the topper.
I now they have the 5 holes for drainage, and the smaller lid.
But what other differences are there compared to the standard non-OAI housing?
1970-only had a ~1/2" hole in the underside of the air intake horn on the OAI filter housing (base).
Some 1970 models had vapor recovery canisters. And in 1970 there were three hoses on those canisters. The third hose was a vent hose that went to an elbow installed in the hole on the underside of the air horn.
You're right, those dual breather openings are a requirement on a real OAI air cleaner base. However, other cars with dual breathers (such as 4-speed 442s) also had dual openings.
If the decal is original, a 1970 air cleaner base will have an "ON" decal. We had a discussion on here a while back about the decals.
https://classicoldsmobile.com/forums...-118797/page2/
Last edited by VC455; November 15th, 2023 at 10:10 AM. Reason: eliminated redundancy
pfergy600
November 17th, 2015 02:20 PM
