DIY OAI Air filter housing.......
Old Dec 9, 2009 | 07:28 AM
Charlloots's Avatar
After coming across Boldsmobiles post and seeing what a great job he did on his homemade OAI housing.
i finally got around to making a housing for my 14 inch airfilter ,having that velocity stack under the hood was driving me crazy.i so prefer stock "appearing" to the untrained eye.
it was pretty simple, went to homedepo purchased a black flo tech sump basin 23.99 with a 15 1/2 inch inside bottom, and 10 ft of 1 1/4 rubber self stick weather stripping.6.99
first using a jigsaw with a fine tooth blade,i cut a 11 inch circle out of the bottom,and cut the basin to 4 1/4 inches.then screwed with 3/16 self tapping zippies the bottom base from the air filter to the basin,and sprayed it with lowgloss high heat paint
then stuck the weather stripping around the top of the new housing inside and out leaving 3/4 exposed over the top of the housing mating the two to each others self stick..now im just waiting for a keep your GM car all GM decal.
let me know what you guys think.
Old Dec 9, 2009 | 07:49 AM
71rocket's Avatar
car nut farmer
Great idea. I like home engineering.
Old Dec 9, 2009 | 07:57 AM
Charlloots's Avatar
Thanks Bud !
Old Dec 9, 2009 | 08:09 AM
The Stickman's Avatar
Looks great, do you have any in progress pics to see better the steps involved?
Old Dec 9, 2009 | 08:17 AM
Charlloots's Avatar
Thanks Stickman,
it was pretty straight foward , measure and cut. i will take it off and take some pictures of the inside and bottom,this will give you a better idea of how it was made.
Old Dec 9, 2009 | 08:22 AM
Danny Boy's Avatar
1972 98 & 1984 H/O
LOOKS NICE...but, you need to put on a "keep your GM car all GM" decal and then put a Home Depot sticker over that.
Old Dec 9, 2009 | 09:09 AM
Charlloots's Avatar
LOL, Thanks danny.
the GM sticker is in the mail.
as far as the Home depo sticker how about
a 350 H/D sticker on the hood scoop.
Old Dec 9, 2009 | 09:19 AM
Charlloots's Avatar
these pics should give you a better idea. how straight foward it was.
i cut the circle with a jigsaw and cut the basin down to 4 1/4 with a sawsall both cut with ease with a fine tooth blade.
Old Dec 9, 2009 | 09:30 AM
Fyi
I din't know if you knew this or not but here's some more infor for you
Here's the 69 H/O tech bulletin about drilling holes in the bottom of your base http://members.***.net/witrob/scoop/scoop.html
Old Dec 9, 2009 | 09:43 AM
Charlloots's Avatar
Thanks for the info jamesbo,
i knew about the drain holes ,decided not to only because the car is not a dailey driver and most likely 99.9 % will not be driven in the rain.
Old Dec 21, 2009 | 10:31 AM
AZ442's Avatar
charlloots,
Do you have a flowtec Part # for the pump basin you used? Can't find them on line or here in AZ.
Old Dec 21, 2009 | 11:01 AM
Have you gotten a chance to drive it and get any impressions of the mod? Any better performance?
Old Dec 21, 2009 | 12:14 PM
Very cool. Did you use the air cleaner base from your stock Oldsmobile air cleaner, or did you use an air cleaner base from an aftermarket air cleaner? I suppose either would work equally well. Defenitely ingenious.
mphyle0927
Sep 19, 2013 07:16 PM
dieselc
Dec 22, 2010 08:29 AM
AZ442
May 13, 2010 08:58 AM
dandlrestoration
Jan 19, 2010 09:34 PM
