69 vs. 70 A Body Core Support
Well, all "A-body" core supports are completely different. I assume you mean Oldsmobile A-body. The biggest difference is the hood latch, but the two years are different and do not easily interchange. Every single Cutlass core support from 1964 to 1972 are one year only.
He said if I want to find a 70 support he would swap it out but I'm really at the end of my restoration rope and budget. Unless using what I have will cause some sort of irreversible damage I think I'm going to leave it for now.
The '69 core support has some value if it is in good shape. They do not reproduce so good ones for high end restorations are hard to find. The 70 core supports are reproduced and available through some of the vendors.
Thanks for the heads up Tim. That's something to think about moving forward. How do I know if it's truly a 69 support? Is it stamped somewhere?
There's a good looking 70 core support in the classifieds right now FYI.
Edit not mine idk the seller
https://classicoldsmobile.com/forums...e-support.html
jensenracing77
January 25th, 2018 04:16 PM
Oldssupreme
August 19th, 2016 09:36 AM
adamjana88
September 2nd, 2015 06:04 PM
