68 Brake Booster Info
Old Sep 24, 2021 | 09:29 AM
66-3X2 442's Avatar
Can someone verify the OEM not repo vacuum valve on a 68 booster being straight or a 90*? OEM only please.
Old Sep 24, 2021 | 10:16 AM
If your talking about the plastic check valve, they are interchangeable.
Old Sep 24, 2021 | 10:25 AM
66-3X2 442's Avatar
Are you positive about that? The 64-67 boosters used a straight valve and is of a larger diameter than the 90* valves. If you buy a repo booster for a 64-67 it has a 90* valve and WILL NOT accept the straight valve.
Old Sep 24, 2021 | 11:41 AM
Mike,
From the parts book (Sept 1968 printing)
Tthe 66-67 FULL SIZE cars use the same check valve and same rubber grommet as the ones on the 68-69 A-body cars. That's P/N 5467023 valve and 5461808 grommet.
The 1966-67 A-body cars use check valve 5464705 and grommet 5461059.
Old Sep 24, 2021 | 01:51 PM
68442's Avatar
1968 OEM A body is a 90*
Old Sep 24, 2021 | 02:08 PM
66-3X2 442's Avatar
Mike,
Thanks Joe,appreciate the info.
Old Sep 24, 2021 | 02:09 PM
66-3X2 442's Avatar
Thanks for the info.
66-3X2 442
Brakes/Hydraulic Systems
Sep 23, 2021 03:52 PM
pops1958
Vista Cruiser & Wagons
Jul 23, 2018 08:49 AM
64Rocket
Nov 14, 2012 06:14 PM
smcurro
Oct 14, 2011 12:55 PM
olds4life
Apr 26, 2011 09:05 AM
