66-67 Throttle linkage conversion
If I remember correctly, there was someone who was making a throttle linkage adapter that would take an automatic throttle linkage for a 66-67 and it would eliminate the switch making it like a 4 speed or manual trans throttle linkage. Does anyone have the info on who was doing that?
Larry
lemoldsnut@aol.com
Larry
lemoldsnut@aol.com
I am aware that I can just remove the wiring pig tail to the trans and run an automatic linkage with a manual trans. I ran into this item a while back and we were discussing it and I was curious if anyone remembers where or who has them. I also heard someone was making the correct piece to convert the non-tripower linkage to tripower linkage.
Just hoping someone had more info than me.
Larry
Larry
Bell crank
I believe mike who was making the L69 3x2 conversion bracket for auto and stick throttle linkages is now making one to clone the auto linkage to a stick linkage for the 4v. Good luck. He's on ebay i think mike442 or u can look up l69 bell crank or Oldsmobile bell crank.
