66-67 Throttle linkage conversion
Old Jul 20, 2014 | 06:50 AM
lemoldsnut's Avatar
If I remember correctly, there was someone who was making a throttle linkage adapter that would take an automatic throttle linkage for a 66-67 and it would eliminate the switch making it like a 4 speed or manual trans throttle linkage. Does anyone have the info on who was doing that?
Larry
lemoldsnut@aol.com
Old Jul 20, 2014 | 07:00 AM
Are you trying to remove the switch? You can use the same linkage, just unplug the wires that run down to the trans.
Old Jul 20, 2014 | 08:01 AM
Sea five's Avatar
I also saw that. I believe it was on e bay
Old Jul 20, 2014 | 09:25 AM
RandyS's Avatar
Member 'Mikes442' may be able to help you out.
Old Aug 29, 2014 | 07:46 AM
lemoldsnut's Avatar
I am aware that I can just remove the wiring pig tail to the trans and run an automatic linkage with a manual trans. I ran into this item a while back and we were discussing it and I was curious if anyone remembers where or who has them. I also heard someone was making the correct piece to convert the non-tripower linkage to tripower linkage.
Just hoping someone had more info than me.
Larry
Old Sep 24, 2014 | 03:30 AM
L69's Avatar
L69
Bell crank
I believe mike who was making the L69 3x2 conversion bracket for auto and stick throttle linkages is now making one to clone the auto linkage to a stick linkage for the 4v. Good luck. He's on ebay i think mike442 or u can look up l69 bell crank or Oldsmobile bell crank.
therobski
Apr 2, 2010 07:33 AM
gearheads78
Aug 6, 2008 07:44 PM
66starfire
Apr 29, 2007 08:46 PM
66starfire
Dec 21, 2006 01:57 PM
1964 oldsmobile 442
Sep 5, 2006 11:19 PM
