64 Cutlass Coupe window chanel
Old Mar 18, 2023 | 08:35 PM
jmcghee's Avatar
Anyone know of a source, for new quarter window channels, for a 64 Cutlass coupe?
Old Mar 19, 2023 | 04:40 AM
oldolds88's Avatar
which channel do you need,i have some parts cars
Old Mar 19, 2023 | 05:36 AM
jmcghee's Avatar
I need the chanels for the back seat windows. The ones the regulator attach too. Car is a 2door post.
Old Mar 19, 2023 | 08:08 AM
jmos4's Avatar
Hi,
Haven't looked close to rear windows, but if they are like the fronts they sell steel channel, for window grip strip/rubber this place sells it maybe the channel as well
https://www.restorationspecialties.c...t_p_36790.html
Regards,
Jim
Old Mar 19, 2023 | 02:23 PM
Tri-Carb's Avatar
Try https://www.steelerubber.com/search?...e=2-door-coupe
Old Mar 19, 2023 | 03:06 PM
jmcghee's Avatar
thanks for the suggestins guys, But I need the metal chanel . All am finding is on the linked sites is the rubber. Passenger side cleaned and welded will work. Driver side crumbled to dust
Old Mar 19, 2023 | 06:42 PM
72cuttys's Avatar
This is the part in question. What the quarter windows in a 2 door post sit in.
Old Mar 19, 2023 | 06:46 PM
jmos4's Avatar
Hi again,
Here is the channel, you will have to cut and weld the brackets onto the channel, not sure on size but this should give you a starting point
https://www.restorationspecialties.c...nel_c_321.html
It's a U-channel that the rubber sits in and squeezes the glass
Regards,
Jim
Old Mar 20, 2023 | 04:38 PM
jmcghee's Avatar
thank you jmos4
Old Mar 20, 2023 | 05:17 PM
oldolds88's Avatar
pmed you
55Oldsmobile$
Oct 3, 2021 01:28 PM
jmcghee
Jul 7, 2021 05:06 PM
malibru
Oct 20, 2015 12:07 PM
pontiac1
Body work
Oct 1, 2011 05:03 PM
68cutlassman
Mar 5, 2008 10:52 AM
