61-63 F85 power booster installation
there are many parts that you need beyond the booster. the master cylinder has a bigger bore for the power brakes. all the brake pedal and rods are differant and the vacuum tank under the hood on the right side fender will be needed. it took me a while to understand how this system works. it is a pretty crude setup but does work if you have all the adjustments right. if you never seen one to start with it is not going to be easy to install.
100_6161.jpg?t=1344201744
100_6036.jpg?t=1327624352
zodiacblueS
Brakes/Hydraulic Systems
44
October 12th, 2014 03:22 PM
