61-63 F85 power booster installation
Old Aug 5, 2012 | 01:11 PM
Jetfire63's Avatar
I just picked up the under dash brake booster and I want to install it in my '63 Jetfire. Has anyone ever done this before? What other parts will I need. Thanks, Ken
Old Aug 5, 2012 | 02:24 PM
jensenracing77's Avatar
there are many parts that you need beyond the booster. the master cylinder has a bigger bore for the power brakes. all the brake pedal and rods are differant and the vacuum tank under the hood on the right side fender will be needed. it took me a while to understand how this system works. it is a pretty crude setup but does work if you have all the adjustments right. if you never seen one to start with it is not going to be easy to install.
100_6161.jpg?t=1344201744
100_6036.jpg?t=1327624352
Old Aug 5, 2012 | 02:29 PM
are you on the Jetfire forum? do you still have the Turbo on the car? any pictures?
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
4x4jimbo
May 16, 2012 12:08 PM
Chumley
Oct 11, 2010 08:25 AM
Vinny72olds
Apr 16, 2009 07:40 AM
iuhoops83
Nov 7, 2008 02:04 PM
