425 head removal STUCK
I have a 425 that has studs in it instead of head bolts. is that normal? tips for getting loose? Stuck a crow bar in the exhaust port and pull whole engine moves but no movement on the head
I don't think Oldsmobile ever used studs from the factory. Maybe they should have on the later diesels?
If you have an engine hoist you can try to use it to lift up on the exhaust port. Just make sure everything is loose first.
If the engine has studs holding the heads on, they are aftermarket.
As mentioned, jam two nut’s together and try to back out the studs. Once loose from the lock, you may need to remove the head and studs together. I know it’s a tight fit removing pushrods around heater cases and brake boosters, I’m betting head studs would be just as bad if not worse.
Cranking is insanity, lol, but might work. The valvetrain, I assume, is disconnected, so the ether won't make it into the chamber unless you pushed down the valve and shot it in the intake port, now that would be nuts. If that is done, put some nuts on the bolts up an inch or so so the thing doesn't jump too high.
Big rubber mallet, beat sideways. Also, make sure you got all the nuts off.
shoot a bunch of liquid wrench down alongside the stud going into the block. Tap them and get some vibration going shoot them again and let them sit for about four or five hours and go back there with the double nut and they will come off.
Anyone who has pulled a head on an old flathead with 20 plus studs can sympathize. There is always one or two that are stuck. You'll probably find the stuck one is open to the elements and not under the valve cover.
Cranking it over was half a joke. The head won't go flying, it'll just pop up. The ether was a full joke!
