405233 intake
405233 intake
Was talking to a guy about olds intakes I was under the impression only 69 hurst and 70/71. W cars have the nipple on them did some cast iron intakes in 70 come with them to ?
Yes and no. 1970 442s with manual transmissions, even though not W-30, used what was called "dual ventilation" for the PCV system. They had a nipple pressed into the cast iron intake manifold. Same manifold casting number as for the automatics, but different part number, since it was drilled and nipple pressed in.
However, this was not the same 405233 cast iron manifold used on '69 Hurst/Olds, if that was your question.
Most if not all the 70-72 RWD 4-bbl manifolds have that boss, but on the vast majority, that's all it is. They generally did not get the boss drilled and fitted.
Which is a good start, because adding that boss is quite a PITA.
Nickyloves442s
October 24th, 2012 04:55 PM
svnt442
July 17th, 2011 04:43 PM
