405233 intake
Old Apr 12, 2016 | 11:39 AM
firefrost gold's Avatar
405233 intake
Was talking to a guy about olds intakes I was under the impression only 69 hurst and 70/71. W cars have the nipple on them did some cast iron intakes in 70 come with them to ?
Old Apr 12, 2016 | 02:14 PM
BlackGold's Avatar
Yes and no. 1970 442s with manual transmissions, even though not W-30, used what was called "dual ventilation" for the PCV system. They had a nipple pressed into the cast iron intake manifold. Same manifold casting number as for the automatics, but different part number, since it was drilled and nipple pressed in.
However, this was not the same 405233 cast iron manifold used on '69 Hurst/Olds, if that was your question.
Old Apr 12, 2016 | 06:25 PM
Octania's Avatar
Most if not all the 70-72 RWD 4-bbl manifolds have that boss, but on the vast majority, that's all it is. They generally did not get the boss drilled and fitted.
Which is a good start, because adding that boss is quite a PITA.
Old Apr 12, 2016 | 06:28 PM
Mr Shifty Sidney's Avatar
Is the nipple for the extra pcv available aftermarket?
Don W
Old Apr 13, 2016 | 03:24 PM
Old Apr 13, 2016 | 03:44 PM
Octania's Avatar
Don W
PN 405143 to the best of my knowledge cannot be found. I have to make them.
I use 1/2" OD hydraulic tubing and a compression fitting collar to form the bulge.
Old Apr 13, 2016 | 03:49 PM
Thanks Octania
Don W
Octania
Jun 13, 2022 08:07 AM
Octania
Aug 27, 2013 07:22 PM
Nickyloves442s
Oct 24, 2012 04:55 PM
svnt442
Jul 17, 2011 04:43 PM
71cuttyS
Oct 31, 2007 04:58 PM
