394 timing cover use iron or aluminum?
Old April 22nd, 2014 | 09:55 PM
dynamic63's Avatar
i have a 63 and my replacemet motor is a 61. the 61 has a cast iron timing chain cover the 63 has aluminum. now as being a mechanic by trade ive had real horrrorrr stories of ford aluminum covers. water pump bolts snapping. castings oxidizing and pushing gaskets, pin holes.which would you use? only drawbacks i see to iron is , pump more expensive,bolts are for a generator bracket(at bracket too low to hold an alt, tried it wil have to modify), ananyne who knows these cars wil pick it off as not being 63. as for the aluminum the draback is oxidation,bolts freeze gaskets push paint flakes. any insight? thanks allan
Old April 23rd, 2014 | 07:29 AM
D. Yaros's Avatar
Never had any problem with the factory timing cover on my '63 well into 6 years after it rolled of the assembly line?
Old April 23rd, 2014 | 08:47 AM
Run to Rund's Avatar
No choice. The blocks are different, afaik.
Old April 23rd, 2014 | 09:43 PM
dynamic63's Avatar
i didnt think the blocks were different. guess that makes that delema solved. good thing i didnt get a new water pump for the 63 cover. the 63 fuel pump should work right? thanks
jensenracing77
September 5th, 2014 01:51 PM
cutlassefi
November 12th, 2013 10:51 AM
joepenoso
November 23rd, 2011 02:13 PM
RATCHETMASTER
October 29th, 2011 07:27 PM
442scotty
May 13th, 2009 06:42 PM
