394 timing cover use iron or aluminum?
Old Apr 22, 2014 | 08:55 PM
dynamic63's Avatar
i have a 63 and my replacemet motor is a 61. the 61 has a cast iron timing chain cover the 63 has aluminum. now as being a mechanic by trade ive had real horrrorrr stories of ford aluminum covers. water pump bolts snapping. castings oxidizing and pushing gaskets, pin holes.which would you use? only drawbacks i see to iron is , pump more expensive,bolts are for a generator bracket(at bracket too low to hold an alt, tried it wil have to modify), ananyne who knows these cars wil pick it off as not being 63. as for the aluminum the draback is oxidation,bolts freeze gaskets push paint flakes. any insight? thanks allan
Old Apr 23, 2014 | 06:29 AM
D. Yaros's Avatar
Never had any problem with the factory timing cover on my '63 well into 6 years after it rolled of the assembly line?
Old Apr 23, 2014 | 07:47 AM
Run to Rund's Avatar
No choice. The blocks are different, afaik.
Old Apr 23, 2014 | 08:43 PM
dynamic63's Avatar
i didnt think the blocks were different. guess that makes that delema solved. good thing i didnt get a new water pump for the 63 cover. the 63 fuel pump should work right? thanks
jensenracing77
Sep 5, 2014 12:51 PM
cutlassefi
Nov 12, 2013 09:51 AM
joepenoso
Nov 23, 2011 01:13 PM
RATCHETMASTER
Oct 29, 2011 06:27 PM
442scotty
May 13, 2009 05:42 PM
