330 Heads
Old Mar 10, 2017 | 03:40 PM
MudEye's Avatar
330 Heads
I've got the high compression 330. Have a guy who has had 2 heads redone at a good price. But He doesn't know anything about them ( inherited them )
Will any 330 heads work on my h.c. 330 work ?
Old Mar 10, 2017 | 04:10 PM
svnt442's Avatar
The CR is changed with the pistons, not the heads (generally speaking) so the same number on the head (2, 3, 4, stc...) SHOULD net the same CR so long as they haven't been cut or the chambers polished.
Old Mar 10, 2017 | 04:37 PM
MudEye's Avatar
He said they're magged and no cracks . Full valve job. New springs and upgraded to positive seals. But the heads were not resurfaced... Do they have to be resurfaced??
Old Mar 10, 2017 | 05:04 PM
Not if they're flat.
Watch out for valve jobs - if it was done by a "Chevy guy," they may not have been careful about getting all of them to the same depth.
Bring a straightedge and lay it across the valve stems to be sure they're all the same height.
Old Mar 11, 2017 | 02:10 PM
What year 330? The No. 1 heads used on the 1964 330 motors have the one-year-only shaft mount rocker arms.
Old Mar 11, 2017 | 05:01 PM
MudEye's Avatar
I've got the 67 cutlass Supreme all original....H.C. engine...Thanks!
Old Mar 11, 2017 | 05:11 PM
MudEye's Avatar
I have the high compression motor. Does it matter if these may come from the lower compression...He doesn't know.. Thanks
Old Mar 11, 2017 | 05:50 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
No, as said the pistons are what changes compression. I would get the .028" head gaskets from Rocket Racing, unless you want lower compression with .040" head gaskets vs the factory .017" shim gaskets.
Old Mar 12, 2017 | 04:50 AM
But you also need to know what year the OTHER heads are that you are thinking of getting. 1964 330 heads won't work on your 67 motor.
Old Mar 12, 2017 | 06:42 AM
I just reread your post, I thought you said #2 heads. The 64 #1 heads needs both shafts and rocker arms complete to be use able. The #2 heads use non adjustable 3/8" rocker arms but easier find parts or go to an adjustable set up. Is the 67 330 a 39 degree motor? I have heard both have been found as well as some with cast cranks. It might require slight clearancing on the heads at the pushrods. I did the same thing, picked up a pair of #6 heads with $1200 worth of parts and work, big intake valves, positive seals and new guides with upgraded springs for $400. Ask him the big numbers on the heads.
Old Mar 12, 2017 | 11:09 AM
MudEye's Avatar
He said they were # 8 heads......
Old Mar 12, 2017 | 11:19 AM
#8 heads are not the same, they are 350 heads with big 79cc chambers, your heads are 60 to 64cc.
Old Mar 12, 2017 | 11:39 AM
MudEye's Avatar
Ok....So not all olds 350 and 330 parts are interchangeable.....
Thanks!
Old Mar 12, 2017 | 11:47 AM
They're interchangeable, but when you interchange them, you will get different results.
Old Mar 12, 2017 | 12:52 PM
lemoldsnut's Avatar
The 67 330 heads are #4 and are very good heads. So what you are being told is if you put the #8 heads on you will lose some of the compression. The #8 heads have larger combustion chambers than the #4 heads that your 330 has stock. If I remember right #4 heads have a 60 cc combustion chamber and #8 is 79 CC. They will physically interchange. Just not what most of us would do.
Old Mar 12, 2017 | 12:59 PM
MudEye's Avatar
Good advice...they were so cheap ( inexpensively priced ) that it was very tempting to take the chance...but now that I know....
Old Mar 12, 2017 | 02:58 PM
Thanks!
Don't confuse "interchangeable" with "identical". As noted, the #8 heads will bolt on and the engine will run. The larger chambers will lower CR considerably.
Old Mar 12, 2017 | 03:28 PM
You will lose over a point of compression. The #8 heads also need a lip removed under the exhaust valve. I have measured the #8 heads, on 2 pairs around 77-78CC, slightly better than spec
Old Mar 12, 2017 | 04:37 PM
MudEye's Avatar
Couldn't measure valve stem height cause the guy I've been corresponding with is on Ebay.
He said he inherited engine heads and such when He bought a machine shop that closed. there were heads there that people didn't pick up or pay for...This was one of them. Said they were done by the largest head rehauler in California I believe. They look nice for 160 bucks for the pair. If anyone is interested ....Here is the link. http://www.ebay.com/itm/Oldsmobile-S...3D282387164674 Wow! what a link!!! Just type in Olds heads on ebay search. Gold and pretty...
Old Mar 12, 2017 | 04:44 PM
$270 with the shipping.
Last pair of #6 heads I bought, with an unknown recent valve job, was $50.
Last time I tried to give away a pair of #8 heads, in good condition, I failed.
Old Mar 12, 2017 | 05:00 PM
MudEye's Avatar
Lol! oh well.......Glad I didn't buy I guess.....
Old Mar 12, 2017 | 05:42 PM
I was curious so I ran numbers through a compression calculator and got ~1.6 point drop, so that HC engine would become a LC engine with maybe 8.5:1 or so.
Nor Cal Andy
Aug 22, 2011 07:17 PM
65cutty
Oct 30, 2008 08:27 AM
65cutty
Aug 27, 2008 10:09 AM
Run to Rund
Aug 4, 2008 02:08 PM
DennisG.
May 23, 2008 12:00 PM
