324 ac pulley for balancer
Old February 3rd, 2019, 10:00 AM
Dennis 55 olds's Avatar
Looking for a 3 groove balancer for 303/324 or single add on pulley like used with aftermarket units for 303/324/371/394..... Dennis 55 olds 573 434 4501
Dennis 55 olds is offline
Old February 3rd, 2019, 11:18 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I don't believe the 324 ever offered a 3 groove pulley. The standard car was 1 groove, power steering added a groove and AC added two more grooves since the compressor had two belts. I don't know how you would add a pulley since the pulley is actually part of the harmonic balancer. You will also need the matching water pump pulley. The 4 groove ones are very hard to come by.
redoldsman is offline
Old February 3rd, 2019, 11:36 AM
Tedd Thompson's Avatar
X2 what redoldsman said. What are you trying to achieve, adding AC?.... Tedd
Tedd Thompson is offline
Old February 3rd, 2019, 12:03 PM
324 ac pully for ballancer
actually I have access to a 55 98 with factory ac and it has a 3 groove balancer. I groove for ps, the other 2 for a matched pair of belts that run the generator and ac and they ran like that through 64. One ones tgat I had installed aftermarket ac on they just provided a single pulley that was held on with the main balancer bolt and had a key to grab about 1/8 to 3/16 deep into the existing balancer. I grew uo with these cars and can provide a pic of existing factory ac if it would help ya. Right now I am off frame restoring a 55 Holiday 4dr and have found and bought a working Autronic eye, factory ac, wonderbar radio and now just need a power antenna and power window regulatora for 4 dr hard top. Thank you guys....Dennis
Old February 3rd, 2019, 12:43 PM
redoldsman's Avatar
I have a 4 groove harmonic balancer and water pump pulley on my 54. Obviously they did not come on the car. The first two grooves from the front were for the AC compressor and I am only using one on my Sanden compressor. The third groove is for the generator and the last groove is for the power steering. Good luck on your restoration.
Old February 3rd, 2019, 12:58 PM
Wow...never saw 5hat on any...maybe its because its an aftermarket....if time allows send me a picture of 5hat and I will send you a pic of this 55 98 with factory ac...its all interesting....my 61 s88 with factory ac is the same way...front 2 groves are for gen and ac and the rear groove is for ps......Would love to see pics of yer 54. I am just now finishing the body rotissery so in the next week or 2 I will finally get my 55 body off the frame. Found the complete factory 55 ac less pulleys for $625 to my door including under dash control and duct work as well as copper lines....a real find
Old February 3rd, 2019, 01:16 PM
Old February 3rd, 2019, 01:20 PM
Hey redoldsman.... What is a good email address so i can send a pic of this 55 98 with factory air 3 groove balancer and water pump pulleys to. Also... I would love to see the setup on yer 54 as well as pictures of it. My email is primitivepetellc@yahoo.com. Dennis 55 olds
Old February 10th, 2019, 10:00 AM
[QUOTE=Dennis 55 olds;1152390]Hey redoldsman.... What is a good email address so i can send a pic of this 55 98 with factory air 3 groove balancer and water pump pulleys to. Also... I would love to see the setup on yer 54 as well as pictures of it. My email is primitivepetellc@yahoo.com. Dennis 55 olds[....i have not been able to upload it on here for some reason..../QUOTE]
Old February 10th, 2019, 03:40 PM
redoldsman's Avatar
Dennis:
Pictures have been sent.
Glenn
motorcitydeuce
March 28th, 2018 08:43 PM
1PDQ55
June 17th, 2015 06:11 AM
beepac
May 19th, 2015 08:42 AM
Johnny HR
August 4th, 2014 08:26 PM
knighthawk
February 8th, 2011 01:24 AM
Quick Reply: 324 ac pulley for balancer
