Power steering pulley '68 98 455 w/AC
Old May 11, 2015 | 09:11 AM
beepac's Avatar
Hi All -
I have managed to damage my power steering pump pulley while removing it on my '68 Olds 98 w/ac. The pulley measures 61/2 inches across. Is the same diameter pulley used on a Cutlass from that year?
Any thoughts welcome of course.
Thanks - Brian
Old May 11, 2015 | 09:23 AM
Originally Posted by beepac
Hi All -
Thanks - Brian
If this is a single groove pulley retained with a nut and key, most of the pulleys from the late 60s/early 70s will work. The pump is in the same place on all Olds V8 motors of that vintage.
Old May 11, 2015 | 09:27 AM
beepac's Avatar
Hi Joe - It's a double groove pulley retained with a nut only.
- Brian
Old May 11, 2015 | 11:38 AM
There should be a 2 letter code on the pulley to identify it. Knowing that will make finding an appropriate replacement easier.
Old May 16, 2015 | 09:52 AM
Octania's Avatar
Sounds like the KH pulley. The trick will be to get another one w/o damaging it too. There is a way. I can get one but it has rust. Try an ePay search maybe. You need one with the keyway. Watch for the "KH" stamp and see if yours has that code. 68-70 or so all Olds with AC
Old May 16, 2015 | 02:33 PM
lunaboy's Avatar
The Rocket Astronomer
i have one on a pump from a 68 cutlass.
Old May 19, 2015 | 08:42 AM
oddball's Avatar
You can get the Dorman power steering pulley catalog off their site and see if one of their general service replacement parts matches, or at least "close enough".
68Tom
Oct 24, 2010 07:55 PM
Steve Wike
Aug 22, 2010 06:45 PM
msco123
Mar 9, 2010 10:13 AM
oldsonharmont
Suspension & Handling
Feb 9, 2010 06:35 PM
mcutlass1969
Mar 26, 2007 07:09 AM
