307 stalling after a stop
Old November 9th, 2012, 01:47 AM
New 2 Olds
at3reg98's Avatar
I'm guessing the carb needs rebuilding as it's probably the accelerator pump from what I've been told but wanted to ask here. This is the 307 in my '83. If I pull away from a stop without having my foot down on the gas some to raise the idle, it will start to go and then immediately stall out. I can restart it no problem but it will keep happening. Idle itself is where it should be on tach. I don't have any problems cruising or at speed. Just hoping it's not timing or something like that.
at3reg98 is offline
Old November 9th, 2012, 03:13 AM
It could be a lot of things, but it's probably not the accel pump, as that would cause stalling when you DO step on the gas.
I would definitely check timing, as well as checking for vacuum leaks.
MDchanic is offline
Old November 9th, 2012, 07:13 PM
GM Enthusiast
OLD SKL 69's Avatar
Shawn,
I agree with Eric.
1. Timing - make sure it is at least at 20. Can go as high as 25 to 27. Make sure you follow the shop manual as to how to do this. If you are not sure, let me know and I will post instructions.
2. Vacuum lines - These engines have a ton of vacuum lines on them and if they have never been changed, there is a good chance that they are cracked. Replace one line at a time, it can be confusing.
3. Check the function of the EGR valve too. Make sure it is opening and closing properly. Sometimes they still work but get carbon buildup on them. Can be cleaned and reinstalled.
OLD SKL 69 is offline
Old November 10th, 2012, 08:15 AM
Olds_71_442's Avatar
As soon as I read the title I thought of the vacuum lines. I had a 403 in my Trans Am that had cracked lines and it ran the same way until I replaced them.
Olds_71_442 is offline
Old November 10th, 2012, 09:48 AM
New 2 Olds
at3reg98's Avatar
Actually Eric what you described is exactly what happens. If I pull up to a stop, sit there (like at a light), and then at green give it a little gas to go, it will fool you and start to go then immediately fall flat and stall. I have to use my left foot for the brake and hold the gas down some to prevent this. Vacuum hoses are all good, replaced them and a few T fittings that cracked. EGR moves freely.
at3reg98 is offline
Old November 10th, 2012, 06:33 PM
jcdynamic88's Avatar
stalling
do you have too much vacuum going to the egr valve or maybe a bad egr?i would leave it disconnected if it is
jcdynamic88 is offline
Arrowstorm
Suspension & Handling
25
July 29th, 2015 05:52 AM
Firstcutlass
October 5th, 2011 06:21 AM
rlafash
August 22nd, 2011 12:40 PM
Giddy
August 6th, 2008 01:56 PM
chancestoo
December 8th, 2006 05:22 AM
Quick Reply: 307 stalling after a stop
