1972 power steering connection help needed
Old Oct 13, 2015 | 09:50 PM
cobalt's Avatar
1956 oldsmobile
i have a 455 olds engine and putting a 1972 power steering pump on it...but im connecting it to my 1956 olds steering box...one hose matches up connection to connection..but the other hose doesnt have the same size end..whats the best way to be able to use the hose i have for the 72 pump and make it fit the smaller hole of the 1956 olds steering box? thanks
Old Oct 13, 2015 | 10:35 PM
svnt442's Avatar
You are most likely going to have to have one made up to work. You're going to need to find some place that does hydraulic lines to get it done, but it shouldn't be all that expensive.
What you have to do is get measurements and angles needed for the fittings so they can install them properly on the hoses so that they don't bind when you install them in the car.
Having the hoses from both setups will be a big help and gives the builder a good starting point.
Old Oct 14, 2015 | 04:43 AM
toymobile's Avatar
74 Corvette uses a hose that has the fittings you need, most parts stores keep it in stock, Check it out. Good luck.
Johnny
Old Oct 14, 2015 | 05:33 AM
cobalt's Avatar
1956 oldsmobile
i was wondering if i could find a fitting that had a female end that the original 72 would go in and a male the size of the 56...reduceing it down... i think i will see
Old Oct 14, 2015 | 05:40 AM
toymobile's Avatar
If I needed that fitting I would go to my local NAPA, the weatherhead group will offer that.
Good luck
Johny
Old Oct 14, 2015 | 02:58 PM
cobalt's Avatar
1956 oldsmobile
thank johny i will try that
Old Oct 14, 2015 | 03:26 PM
toymobile's Avatar
You need a 3/8 to 5/16 flair fitting,
Johnny
Old Oct 14, 2015 | 03:39 PM
If you have the hose with the correct end for the steering box, you can cut off a short piece of tubing with the correct end and remove the end of the correct hose and use a compression union to mate the two.
Carl75
Jul 6, 2014 04:20 PM
mmurphy77
May 24, 2010 01:49 PM
ELECMAN
Jan 20, 2010 12:57 PM
tarps3
Brakes/Hydraulic Systems
Jun 29, 2008 04:18 PM
justinj
May 29, 2008 08:08 PM
