1972 olds cutlass s 442
Old Apr 18, 2026 | 01:48 PM
72ucodew29's Avatar
My 455 engine number matches the year, plant & sequential of car.
It does not begin with the number 3 for oldsmobile.
The number stamped on block: 022z103899
I recently obtained the build sheet from the
Responses welcomed. Thanks
top of gas tank. It is a Special order Non A/C car with a L75 engine with the w29 package. Could the motor be a manufacturer warranty replacement engine?
Old Apr 18, 2026 | 05:41 PM
Jungle Cat's Avatar
Nice to have that style of build sheet. Only GMAD plant build cars got that. If your VIN last 6 digits are there you are golden
Old Apr 18, 2026 | 06:15 PM
vCode442's Avatar
Vincit qui se vincit
Great find. Yes, as stated the W29 confirms 442, and in ‘72 that package could be added to any available engine, even a 350 2 barrel single exhaust - that’s why there are far more 1972 442s today than ever factory produced.
Looks like yours was delivered in California, and the dual gate indicates VIN fifth letter should be a U.
But many on here won’t believe it - until you post pictures of the car😎
Old Apr 18, 2026 | 07:27 PM
Texas442's Avatar
1971 442 conv
Let's see a picture of your 72 442. We love the '72 W29s. Heck we even re-created the original magazine ad with local original paint 1972 W29's.
Old Apr 18, 2026 | 07:30 PM
72ucodew29's Avatar
Old Apr 18, 2026 | 09:02 PM
kjr442's Avatar
Kjr442
California build Sheet
I love that these California built cars had the build sheet on top of the gas tank.
They’re typically in pretty good shape unless the trunk is completely rotted out.
The Arlington plant liked to throw them under the carpet in the floorboard area. At least that’s where I found a few of them and they’re usually trash from all the leaky windshields.
You’re very fortunate to have this build sheet and what an awesome car you have.
Does the transmission also match?
Old Apr 19, 2026 | 06:39 AM
Jungle Cat's Avatar
My Linden NJ 442 was under the back seat. Except for an inch of missing paper at the top mine is in excellent shape.
Old Apr 19, 2026 | 07:32 AM
Texas442's Avatar
1971 442 conv
Originally Posted by 72ucodew29
My 455 engine number matches the year, plant & sequential of car. It does not begin with the number 3 for oldsmobile..........The number stamped on block: 022z103899....I recently obtained the build sheet from the
Now most of us are curious what are the stamps on the transmission. Does it look like the Top or Bottom of this image?
Old Apr 19, 2026 | 08:44 AM
72ucodew29's Avatar
Engine number
The transmission is a TH 400 but from a 1973 full size oldsmobile.
My engine number does have the 2 for the year and Z for the plant along with the the sequential.
It is my experience to expect the engine number to start with the character 3 for Oldsmobile.
Maybe it is a factory warrantied motor?
And was re stamped. Did Oldsmobile do that? IDK
I did discover the motor was equipped with 30 over forged pistons when I removed it to correct a bad thrust bearing.
Old Apr 19, 2026 | 04:14 PM
cherokeepeople's Avatar
my sister had new red one like in that ad,same stripes and white interior but bench seat.it was a 350 2 bbl a/c car.i still have the th350 trans and the pop for it.
Old Apr 19, 2026 | 04:56 PM
72ucodew29's Avatar
Old May 16, 2026 | 01:31 PM
OLE442's Avatar
Yeah, I have not found a build sheet anywhere in my low mileage 1972 Cutlass 442. It was built in Arlington, Texas. None on the gas tank, none under the carpet and none under the front bucket seats. There is a paper in one of the halves of the rear seat by the seat springs but I did not replace those seat covers so I can't be sure. I may order the rear seat cover from Legendary and install them next winter so I can see what that paper is! I do have the original window sticker so it is verified to be a true original '72 442! See part of window sticker below.
I guess this will serve as verification, but I'd love find a build sheet!
I've found numbers matching for the engine but not seen a number on the TH400 yet. Are there other numbers I should be concerned with?
It is neat that the above owner has a 1972 455 2bbl Cutlass 442! Really neat!
OLE442
LDPotts
May 24, 2025 08:27 AM
chris59
Jun 20, 2024 05:29 AM
Patmcg59
Nov 10, 2022 04:21 PM
w1po
Dec 23, 2021 08:05 AM
markbmccoy
Sep 10, 2015 07:54 PM
